[GeoNode-users] (no subject)
Naresh N naresh919 at gmail.com
Sun Dec 8 23:10:28 PST 2019
Dear Amedo/Simone,
Please see once my post and reply.  Not able to understand? Where the issue.
Is following  require for GeoNode to work as https?
sudo -s "cat server.crt >>
/usr/lib/python2.7/dist-packages/httplib2/cacerts.txt"sudo keytool
-import -alias geonodessl -keystore /etc/ssl/certs/java/cacerts -file
server.crt
Please suggest
Thanks&Regards,
Naresh
On Thu, Dec 5, 2019 at 4:07 PM Naresh N <naresh919 at gmail.com> wrote:
> Dear All,
> As  I posted earlier, we need to enable GeoNode with https but facing the
> issues.   The following are added for https
>  1.   Apache Configured with https and required changes are added in
> geonode.conf as per  mentioned   in
> http://docs.geonode.org/en/2.8.1/tutorials/advanced/geonode_production/ssl.html
> 2.  Tomcat /GeoServer Configuration -
>    (i)Modified the  Server.xml and done required changes
>          <Connector port="8080" protocol="HTTP/1.1"
>     connectionTimeout="20000"
>     URIEncoding="UTF-8"
>     scheme="https"
>     proxyName="<ourDomainName .. for example as* exmaple.com <http://exmaple.com/> *>"
>     proxyPort="443"  />
>    (ii)  Modified /var/lib/tomcat/webapps/geoserver/WEB-INF/web.xml
>        *  Geonode_BASE_URL* to https://ourdomainname
>    (iii) Modified /var/lib/tomcat/webapps/geoserver/data/web.xml))
>          * Proxybaseurl *: * https://*ourdomainname/geoserver
> 3.  GeoNode Configuration - Changed Site Url to https
>    (i)
> /var/lib/tomcat/webapps/geoserver/data/security/auth/geonodAuthProvider/config.xml
>         baseurl to https://ourdoamingname
>    (ii) In local_settings.py and setttings.py
>        a.  sitename and siteurl to https://ourdomainname
>        b.GEOSERVER_LOCATION: *http://ourdomainname:8080/geoserver
> <http://ourdomainname:8080/geoserver>*
>           GEOSERVER_PUBLIC_LOCATION: *https:// ourdomainname/geoserver *
>   After doing the above the changes , *our GeoNode portal is able to
> access with https*, however the following functionalities are not working
>   1. When we are uploading the data, the following error is appearing
>   Tried to make a GET request to
> http://ourdomainname:8080/geoserver/rest/workspaces/default.xml
> <http://localhost:8080/geoserver/rest/workspaces/default.xml> but got a
> 404 status code:'
> 2.  Edit style is not working
>    https://domainname/gs/rest/layers/geonode:_11_19_2019_6450480_1.json
> -- * notfound   (error code:404)*
>   https://ourdomainname/gs/rest/styles/_11_19_2019_6450480_1.xml ---
> error code 500 ( some internal server error)
> In above both are *REST services which are not working* however, When I
> tried to access *http://ourdomainname:8080/geoserver
> <http://ourdomainname:8080/geoserver> it is redirecting to
> https://ourdomainname/geoserver <https://ourdomainname/geoserver>* ( it
> is loading properly)
> Please kindly help me, is somewhere I need to do the REST services
> settings.
> Thanks&Regards,
> Naresh.n
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191209/5c74a778/attachment.html>
More information about the geonode-users mailing list
