[GeoNode-users] Command updatelayers and createsuperuser in docker-compose
Francesco Bartoli
xbartolone at gmail.com
Mon Feb 4 13:35:57 PST 2019
Can you briefly show which commands have been executed and against which container?
Regards,
Francesco
Il 4 feb 2019, 21:43 +0100, Andres Juarez <albertoandres.juarez at gmail.com>, ha scritto:
> Hello everyone
> I continue with Geonode 2.10 in docker, and I find a problem when executing the updatelayers command.
> I have several layers in a postgres database on another server, and I load it through a geoserver store.
> The updatelayers command runs flawlessly and warns me that the layers were updated, but they do not appear in the geonode layers section. However, I can create an empty map and load these same layers using the add layer button, selecting 'Geoserver - Public layers'.
> The same happens when executing createsuperuser, the process ends successfully in the command line, but I can not log in with that user.
> Thank you in advance for any help you can provide.
> Andrés Juarez
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190204/800048d7/attachment.html>
More information about the geonode-users
