[GeoNode-users] (no subject)
Naresh N naresh919 at gmail.com
Wed May 8 04:25:39 PDT 2019
Dear Amedeo and All
Please find the my earlier mail/post , kindly suggest to fix the issues and
enable GeoNode with https
Thanks & Regards,
Naresh.N
On Wed, May 8, 2019 at 10:13 AM Naresh N <naresh919 at gmail.com> wrote:
> Dear Amedeo,
> Thanks for quick response.
> I have changed the GEOSERVER_LOCATION
> to
> http://localhost:8080/geoserver
> but I am getting the error in  while uploading layer  "Tried to make a
> GET request to http://localhost:8080/geoserver/rest/workspaces/default.xml
> but got a 404 status code:'
> I am having doubt in following
> 1. http://localhost:8080/geoserver it is redirecting to http://<our
> domain name>:443/geoserver/web/ and showing the following error
> *Bad Request*
> *Your browser sent a request that this server could not understand.
> Reason: You're speaking plain HTTP to an SSL-enabled server port.
> Instead use the HTTPS scheme to access this URL, please*
> The redirection must be from /etc/tomcat/server.xml of the following code but it is mentioned scheme as *https* but it is redirecting to http
> <Connector port="8080" protocol="HTTP/1.1"
>     connectionTimeout="20000"
>     URIEncoding="UTF-8"
>     scheme="https"
>     proxyName="<ourDomainName .. for example as* exmaple.com <http://exmaple.com/> *>"
>     proxyPort="443"/>
> 2. http://<ourdomainname>:8080/geoserver *is redirecting* to http://
> <ourdomainname>:443/geoserver
> * but*  http://<our domain name>:8080/geoserver/rest/workspaces/default.xml is not redirecting  and as showing 404
> Please help me to resolve the issue and understand the above two points
> Thanks&Regards,
> Naresh.N
> On Tue, May 7, 2019 at 4:05 PM Amedeo Fadini <amefad at gmail.com> wrote:
>> Il giorno mar 7 mag 2019 alle ore 11:52 Naresh N <naresh919 at gmail.com>
>> ha scritto:
>>> Dear Amedeo,
>>> Thanks for your reply. I have changed as advised
>>> but Now  while uploading the data it is showing the error  ' *Tried to
>>> make a GET request to
>>> http://<ourdomainname>:8080/geoserver/rest/workspaces/default.xml but got a
>>> 404 status code*:'
>>> Nope, in this way yo're trying the server is trying to contact geoserver
>> at the URL http://<oudomainname>:8080 and is good that you've a 404
>> error: port 8080 is not exposed to the external but is redirected by apache
>> proxy (yes the geonode conf. seems correct).
>> Port 8080 is only available for localhost as the default tomcat port, try
>> to set
>> GEOSERVER_LOCATION
>> to
>> Amedeo
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190508/a8a5a1e6/attachment-0001.html>
More information about the geonode-users mailing list
