[GeoNode-users] New Install error - no module
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Oct 28 01:41:48 PDT 2019
Dear all,
I understand that might be not so straightforward setup GeoNode, but, on
the other hand, the documentation is quite clear.
Please read it carefully and follow all the steps. You cannot ask people to
provide assistance for free on things that are already fully covered from
the documentation.
Again and for the last time, you are missing the following steps
[image: image.png]
Regards,
Alessio.
Il giorno lun 28 ott 2019 alle ore 00:14 Handy Rusydi <handy at galerigis.com>
ha scritto:
> So do I. I have same issue as you
> Sent from myMail for Android
> Senin, 28 Oktober 2019, 06:11AM +07:00 from Narelle Irvine
> narelle.irvine at gmail.com:
> I have tried installing Geonode Core on a new 8GB computer running Ubuntu
> 18.04.3
> I have the Geoserver working (localhost:8080/geoserver, but not Geonode
> (localhost:8080). Error is unable to connect.
> When I get to the command
> python manage.py collectstatic --no-input
> the response is
> ImportError: No module named osgeo
> I have also seen errors saying
> ImportError: No module named geonode.settings
> Is this related to environment variables? I think I had some issues with
> which user (nirvine or geonode) and the virtualenv as I was working through
> the instructions, but I have tried so many things in the last couple of
> days that I no longer know what is happening.
> I am in the geonode virtual env, and the settings are:
> VIRTUALENVWRAPPER_WORKON_CD=1
> LESSCLOSE=/usr/bin/lesspipe %s %s
> VIRTUALENVWRAPPER_HOOK_DIR=/home/nirvine/Envs
> LANG=en_US.UTF-8
> OLDPWD=/home/nirvine
> WORKON_HOME=/home/nirvine/Envs
> VIRTUAL_ENV=/home/nirvine/Envs/geonode
> S_COLORS=auto
> XDG_SESSION_ID=173
> USER=nirvine
> PWD=/opt/geonode
> HOME=/home/nirvine
> SSH_CLIENT=192.168.20.48 49504 22
> XDG_DATA_DIRS=/usr/local/share:/usr/share:/var/lib/snapd/desktop
> SSH_TTY=/dev/pts/0
> MAIL=/var/mail/nirvine
> VIRTUALENVWRAPPER_SCRIPT=/home/nirvine/.local/bin/virtualenvwrapper.sh
> TERM=xterm
> SHELL=/bin/bash
> SHLVL=1
> LOGNAME=nirvine
> XDG_RUNTIME_DIR=/run/user/1000
> VIRTUALENVWRAPPER_PROJECT_FILENAME=.project
> PATH=/home/nirvine/Envs/geonode/bin:/home/nirvine/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
> PS1=(geonode) \[\e]0;\u@\h: \w\a\]${debian_chroot:+($debian_chroot)}\u@
> \h:\w\$
> LESSOPEN=| /usr/bin/lesspipe %s
> _=/usr/bin/env
> Assistance, please?
> Narelle Irvine
> Ph. 0413592876
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191028/17ce71c9/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191028/17ce71c9/attachment-0001.png>
More information about the geonode-users
