[GeoNode-users] Map options - view vrs edit
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Apr 29 01:36:09 PDT 2020
Not sure I fully understand your question or needs, however initially the
idea was to have to buttons:
"View" - for any user, allows them to access the map for the visualization
only, the editors in edit mode too
"Edit" - visible only to editors, allows them to access the map in edit
mode (quite the same as clicking on the "View")
Those behaviors can be changed by either:
- Modify the templates on django-mapstore-client library
- Override or write your own Hookset to change the behavior
Il giorno mar 28 apr 2020 alle ore 22:05 Jose Cáceres <jose.atyus at gmail.com>
ha scritto:
> Hi everyone,
> I have not much of an issue but a doubt about the option to access a map
> in Geonode.
> I have created a Map and can see it in the map page of Geonode
> (Maps_01.jpg). When I click directly on the opcion "View map" highlighted
> in the image mention before, then I can se the map in Mapstore, but I
> noticed that the end of the url is 'view' as noted on Maps_02.jpg. So when
> I'm here if I clic the layer, it doesn't show the widget option for
> creating graphs.
> But when I click on the map, in the page view, and access the map details
> and click on the View map option inside this page (Maps_03.jpg) I noticed
> that the url end in "edit", and in this case it does shows all the option
> for creating widgets (Maps_04.jpg).
> So my question is, is there a way to define always the "edit" option to
> avoid loading the map and not accessing all of its capabilities?
> I hope the pictures attached help me explain my question
> Thanks,
> José
> José David Cáceres
> Ingeniero Ambiental
> Máster en Tecnologías de la Información Geográfica
> e-mail: jose.atyus at gmail.com
> [image: Mailtrack]
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
> notificado con
> Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 28/04/20
> 14:00:36
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200429/e2718404/attachment.html>
More information about the geonode-users
