[GeoNode-users] Map options - view vrs edit
Jose Cáceres jose.atyus at gmail.com
Wed Apr 29 07:18:18 PDT 2020
Hi Alessio,
Thabks for your response, I'll takr a look at that.
Anyway, my main quiestion is if there is a way for someone who is accessing
the "view" map, to have accesos to the widgets tool to create graphs, that
is only active when you accesos the edit. I may add that if you change
manually the url and change "myurl/maps/number/view" to
"myurl/maps/number/edit"
the function all y will appear and it doesn't matter if you área a
registered user or not
El mié., 29 abr. 2020 2:36 a. m., Alessio Fabiani <
alessio.fabiani at geo-solutions.it> escribió:
> Not sure I fully understand your question or needs, however initially the
> idea was to have to buttons:
> "View" - for any user, allows them to access the map for the visualization
> only, the editors in edit mode too
> "Edit" - visible only to editors, allows them to access the map in edit
> mode (quite the same as clicking on the "View")
> Those behaviors can be changed by either:
>  - Modify the templates on django-mapstore-client library
>  - Override or write your own Hookset to change the behavior
> Il giorno mar 28 apr 2020 alle ore 22:05 Jose Cáceres <
> jose.atyus at gmail.com> ha scritto:
>> Hi everyone,
>> I have not much of an issue but a doubt about the option to access a map
>> in Geonode.
>> I have created a Map and can see it in the map page of Geonode
>> (Maps_01.jpg). When I click directly on the opcion "View map" highlighted
>> in the image mention before, then I can se the map in Mapstore, but I
>> noticed that the end of the url is 'view' as noted on Maps_02.jpg. So when
>> I'm here if I clic the layer, it doesn't show the widget option for
>> creating graphs.
>> But when I click on the map, in the page view, and access the map details
>> and click on the View map option inside this page (Maps_03.jpg) I noticed
>> that the url end in "edit", and in this case it does shows all the option
>> for creating widgets (Maps_04.jpg).
>> So my question is, is there a way to define always the "edit" option to
>> avoid loading the map and not accessing all of its capabilities?
>> I hope the pictures attached help me explain my question
>> Thanks,
>> José
>> José David Cáceres
>> Ingeniero Ambiental
>> Máster en Tecnologías de la Información Geográfica
>> e-mail: jose.atyus at gmail.com
>> [image: Mailtrack]
>> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
>> notificado con
>> Mailtrack
>> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 28/04/20
>> 14:00:36
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200429/8f33f845/attachment-0001.html>
More information about the geonode-users mailing list
