[GeoNode-users] Geonode 3.0 - Set group permissions by Django Admin Interface work only for django ?
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Jul 9 05:22:23 PDT 2020
Correct,
Group Profiles, which must be linked to django Groups, are used to manage
resources permissions
[image: image.png]
I kindly suggest to manage the Groups through the GeoNode UI, unless you
need to do something different.
[image: image.png]
Il giorno gio 9 lug 2020 alle ore 14:11 Fabien GUERREIRO <
fabien.guerreiro at agrosupdijon.fr> ha scritto:
> Dear All,
> We started here to install Geonode 3.0. All works fine (Geoserver, Django,
> Geonode).
> I understand the differents users : user, staff, admin. I want, for
> example, don't let (basic) user create new map.
> I create a group and change permissions (no 'can add map') by Django Admin
> Interface for this group and put the user (we can call him Tom) in this
> group.
> When i go back to the site (Geonode) with Tom user, he can create map (he
> can do it even without the right to do that).
> When I change Tom from (basic) user to staff, he can go to Django Admin
> Interface and can do all except add a map (as i want, but i want it on
> Geonode too).
> I thought the permissions on groups were for all (site Geonode + Django
> Admin), but in facts they are only for Django Admin, is that right ?
> If it's not a bug on my install, someone know how to limit permissions (as
> "add a map" for example) for basics users ?
> Thank you for your time in advance.
> Kind regards
> *Fabien GUERREIRO*
> *Chef de projets en géomatique *
> *Direction des systèmes d'information - Cnerta-Web*
> *AGROSUP Dijon - Grands champs - bureau 211, BP 87999, 21079 Dijon cedex*
> <http://www.openstreetmap.org/?mlat=47.30961&mlon=5.06420#map=17/47.30960/5.06420>
> *tel : 03.80.77.29.52*
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200709/df86901f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200709/df86901f/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200709/df86901f/attachment-0003.png>
More information about the geonode-users
