[GeoNode-users] Geonode 3.0 - Set group permissions by Django Admin Interface work only for django ?
Fabien GUERREIRO
fabien.guerreiro at agrosupdijon.fr
Thu Jul 9 05:43:08 PDT 2020
Hi and thank you for your response,
I manage groups through the GeoNode UI too. I saw group / group profile are the same things between GeoNode UI and Django Admin Interface.
But permissions for the group are only through the Django Admin Interface :
But theses permissions are only for Django Admin Interface - it doesn't work in GeoNode UI.
So how can we do a group for GeoNode UI who can't add a new map ?
Lot of others permissions are ok from GeoNode UI (modify map...) on an existing map, but if i don't want to let users create new maps or upload datas, i can't.
Is it possible to manage user's permissions or affect groups permissions on the Geonode UI ? (i speak about permissions like revoke "can add map")
Kind regards,
Fabien GUERREIRO
Chef de projets en géomatique
Direction des systèmes d'information - Cnerta-Web
[ http://www.openstreetmap.org/?mlat=47.30961&mlon=5.06420#map=17/47.30960/5.06420 | AGROSUP Dijon - Grands champs - bureau 211, BP 87999, 21079 Dijon cedex ]
tel : 03.80.77.29.52
De: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
À: "fabien guerreiro" <fabien.guerreiro at agrosupdijon.fr>
Cc: "geonode-users" <geonode-users at lists.osgeo.org>
Envoyé: Jeudi 9 Juillet 2020 14:22:23
Objet: Re: [GeoNode-users] Geonode 3.0 - Set group permissions by Django Admin Interface work only for django ?
Correct,
Group Profiles, which must be linked to django Groups, are used to manage resources permissions
I kindly suggest to manage the Groups through the GeoNode UI, unless you need to do something different.
Il giorno gio 9 lug 2020 alle ore 14:11 Fabien GUERREIRO < [ mailto:fabien.guerreiro at agrosupdijon.fr | fabien.guerreiro at agrosupdijon.fr ] > ha scritto:
Dear All,
We started here to install Geonode 3.0. All works fine (Geoserver, Django, Geonode).
I understand the differents users : user, staff, admin. I want, for example, don't let (basic) user create new map.
I create a group and change permissions (no 'can add map') by Django Admin Interface for this group and put the user (we can call him Tom) in this group.
When i go back to the site (Geonode) with Tom user, he can create map (he can do it even without the right to do that).
When I change Tom from (basic) user to staff, he can go to Django Admin Interface and can do all except add a map (as i want, but i want it on Geonode too).
I thought the permissions on groups were for all (site Geonode + Django Admin), but in facts they are only for Django Admin, is that right ?
If it's not a bug on my install, someone know how to limit permissions (as "add a map" for example) for basics users ?
Thank you for your time in advance.
Kind regards
Fabien GUERREIRO
geonode-users mailing list
[ mailto:geonode-users at lists.osgeo.org | geonode-users at lists.osgeo.org ]
[ https://lists.osgeo.org/mailman/listinfo/geonode-users | https://lists.osgeo.org/mailman/listinfo/geonode-users ]
GeoServer Professional Services from the experts! Visit [ http://goo.gl/it488V | http://goo.gl/it488V ] for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
[ http://www.geo-solutions.it/ | http://www.geo-solutions.it ]
[ http://twitter.com/geosolutions_it | http://twitter.com/geosolutions_it ]
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200709/c307e5d1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200709/c307e5d1/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200709/c307e5d1/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200709/c307e5d1/attachment-0005.png>
More information about the geonode-users
