[GeoNode-users] Use comma as separator - Mapstore Widgets
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Nov 18 01:17:48 PST 2020
Hi Jose,
this is something specific to the GIS client, MapStore.
I'd suggest to take a look at the MapStore documentation or either try
getting in touch with the MapStore community
https://mapstore.geo-solutions.it/mapstore/#/
Il giorno mer 18 nov 2020 alle ore 06:35 Jose Cáceres <jose.atyus at gmail.com>
ha scritto:
> Hi everyone,
> I have a map that uses the counter widget to track damages caused by
> Hurricane IOTA in here: https://geoportalouot.unah.edu.hn/maps/147/view
> However, the counter uses point as a thousand separator, as seen in the
> attached picture.
> [image: image.png]
> The above number is three hundred and forty eight thousand people
> affected. Since We use point as a decimal separator, this may cause some
> confusion between our users, and I would like to change the point to a
> comma. I found that in the examples shown in the Widget page of mapstore,
> it uses comma:
> [image: image.png]
> But I haven't found where I could make that change.
> Any help would be appreciated.
> Kind regards,
> José David Cáceres
> Ingeniero Ambiental
> Máster en Tecnologías de la Información Geográfica
> e-mail: jose.atyus at gmail.com
> [image: Mailtrack]
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
> notificado con
> Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 17/11/20
> 23:32:27
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201118/7f399bd8/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201118/7f399bd8/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201118/7f399bd8/attachment-0003.png>
More information about the geonode-users
