[GRASS5] New release candidate 3 of GIS Manager 2
Michael Barton
michael.barton at asu.edu
Mon Feb 13 17:24:43 EST 2006
> From: Moritz Lennert <mlennert at club.worldonline.be>
> Date: Mon, 13 Feb 2006 22:13:29 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Grass Developers List <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] New release candidate 3 of GIS Manager 2
> Michael Barton wrote:
> - When trying to use the text tool, I get:
> can't read "anchor": no such variable
> while executing
> "$can($mon) create text $opt($id,xcoord) $opt($id,ycoord) -anchor
> $anchor -justify $opt($id,justify) -width $opt($id,width) -fill
> $opt($id,fill) -..."
> (I assume it is the "Add text layer" button.)
I'll find and fix.
>>>> A Œzoom to current region¹ button so that map displays can use regions
>>>> set using g.region.
> I still find this counter-intuitive. If I set the region using g.region,
> I expect the next "normal" display command to follow this setting. I
> don't find it obvious that I should use a different button to get the
> expected result.
To some extent, this is the 'price' for having a separate zoom for each
display. Each display needs to have its own settings. This means that a
general setting, by default, won't affect an individual display. Otherwise,
it would affect ALL displays and we'd be back to where we were with the
xmonitors.
> Maybe it is possible to add a region setting dialog directly in the
> display window which would then reset the current region definition of
> the this diplay ?
Possible, though it requires a lot of dialog building. But is this any more
intuitive than having a display button that does the same thing?
>>>> A few added convenience features. The one I like the best was inspired
>>>> by Peter Misovic¹s questions about displays and queries. You can now
>>>> save the results of a display query‹in the vector display‹to a new
>>>> vector file (using v.extract).
> Cool !
> Moritz
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
