[GRASS-dev] r.le--after some fixes still needs work
Sun Oct 1 01:09:13 EDT 2006
Glynn Clements wrote:
> BTW, r.le.setup shouldn't be calling R_*/D_*/D* functions. Modules
> which use the display are supposed to be called d.<something> (e.g.
> d.le.setup), not r.<something>.
As a rule, probably not, but it does have 5+ years history using that
name and GRASS 6.0 was released with it being called that..
others modules that fall afoul: r.digit, v.digit, i.points, ...
Hamish
