[GRASS-dev] r.le--after some fixes still needs work
Brad Douglas rez at touchofmadness.com
Sun Oct 1 02:52:21 EDT 2006
On Sun, 2006-10-01 at 18:09 +1300, Hamish wrote:
> Glynn Clements wrote:
> > BTW, r.le.setup shouldn't be calling R_*/D_*/D* functions. Modules
> > which use the display are supposed to be called d.<something> (e.g.
> > d.le.setup), not r.<something>.
> As a rule, probably not, but it does have 5+ years history using that
> name and GRASS 6.0 was released with it being called that..
> others modules that fall afoul: r.digit, v.digit, i.points, ...
This is why r.support is being rewritten as well...
Brad Douglas <rez touchofmadness com>                      KB8UYR
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
