[GRASS-dev] r.flow and G_message
Jachym Cepicky
jachym.cepicky at centrum.cz
Thu Oct 19 15:21:04 EDT 2006
hallo,
i do not know, how to solve fprints in r.flow.
The module use it's own function to print messages (diag)
When i removed this function and rewrite everything with help of
G_message, the result is not well-arranged:
r.flow elevin=elevation.dem aspin=aspect barin=roads flout=tmp1
lgout=tmp2 dsout=tmp3 --o
Opening output files...
WARNING: The vector 'tmp1' already exists and will be overwritten.
Done
Allocating memory: elevation
aspect
barrier
density
flowline header
e/w distances
quantization tolerances
Reading input files: elevation...
aspect
barrier
Precomputing: tangents
e/w distances
re-oriented aspects
Working...
Done%
Writing density file...
Done
Closing files...
Building topology ...
0 primitives registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
Done
De-allocating memory...
Done
What to do? Should I remove all informations about reading, precomputing
and allocating for each raster map? I suggest, that the most verbose
output could look like this:
Allocating memory for maps
Reading input files
Precomputing
Working
Closing files
Building topology
0 areas built
0 isles built
Attaching islands:
Number of nodes : 0
Number of lines : 0
Number of areas : 0
Number of isles : 0
Done
what would you say?
jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
Department of Geoinformation Technologies
Zemedelska 3
613 00, Brno
Czech Republick
e-mail: xcepicky at node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061019/645563e7/attachment.bin
