[GRASS-dev] r.flow and reference information
Thu Oct 19 19:20:22 EDT 2006
Jachym Cepicky wrote:
> while rewriting some modules, so that they use G_message and G_warning
>     instead of fprinf, i found, that r.flow prints reference information
>     to standard error.
> i think, this option (-h) should be removed, because of this information
> can be found in the manual page (or should be).
> so i suggets
> +      G_warning(_("For reference information see manual page. This option will be removed"));
> what do you think?
Seems reasonable enough.
FWIW, if the information was to be retained, fprintf() (or fputs())
would be the correct approach, although it should be a single call
rather than one per line.
Note that the C preprocessor concatenates adjacent string literals, so
large chunks of text can be split into lines like so:
	fprintf(stderr,
		"\n"
		"Version: GRASS5.0, update: October 1999\n"
		"\n"
[snip]
		"Please cite these references in publications where the results of this\n"
		"program are used.\n"
		"\n"
without having to use a separate function call for each line.
