[GRASS-dev] [GRASS-SVN] r65497 - grass/trunk/locale/po
Vaclav Petras
wenzeslaus at gmail.com
Thu Jun 18 07:55:04 PDT 2015
On Thu, Jun 18, 2015 at 10:08 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 18/06/15 15:48, Vaclav Petras wrote:
>> On Wed, Jun 17, 2015 at 10:14 AM, <svn_grass at osgeo.org
>> <mailto:svn_grass at osgeo.org>> wrote:
>> > Modified: grass/trunk/locale/po/grasslibs_fr.po
>> > --- grass/trunk/locale/po/grasslibs_fr.po 2015-06-17 13:53:52
>> UTC (rev 65496)
>> > +++ grass/trunk/locale/po/grasslibs_fr.po 2015-06-17 14:14:56
>> UTC (rev 65497)
>> > @@ -1909,7 +1909,7 @@
>> > #: ../lib/init/grass.py:130 ../lib/gis/parser.c:599
>> > #, fuzzy
>> > msgid "ERROR"
>> > -msgstr "ERREUR :"
>> > +msgstr "ERREUR: "
>> Hi Mortitz, I'm not experienced with translations but it seems to me
>> that the translations doesn't need to be fuzzy
> Don't know about the fuzzy, I didn't touch that.
As I said my experience is limited but I though that when you translate the
string manually, you remove fuzzy.
> and it should not contain
>> colon and space but only "ERREUR".
> Well lib/gis/error.c, l 360ff define:
> prefix_std[0] = "";
> prefix_std[1] = _("WARNING: ");
> prefix_std[2] = _("ERROR: ");
According to your commit there is "ERROR: " but also "ERROR" somewhere.
"ERROR: " should be translated as "ERREUR: " while "ERROR" as "ERREUR".
That's what I was trying to say.
https://trac.osgeo.org/grass/changeset/65497
> so I guess the translation should also have the colon and space. We could
> do something like this:
> char *postfix
> postfix = ": "
> prefix_std[0] = "";
> prefix_std[1] = _("WARNING%s", postfix);
> prefix_std[2] = _("ERROR%s", postfix);
That's unnecessary complicated and it doesn't solve all issues as you note
below. Having two different strings, with and without colon&space, should
account for most of the cases (the state we have now).
> But then again, maybe there are different rules of how to position colons
> and spaces according to locales.
I don't know the current situation but ideally, the error message should be
composed using [in Python syntax]:
_("ERROR: %s") % msg
rather then
_("ERROR: ") + msg
But this would require two step construction of the message since `msg`
again will have again variable parts and it might be too complex or too
cumbersome (especially in C unless there is some gettext feature which
would help us).
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150618/5ae79912/attachment.html>
