[mapguide-users] RE: MySQL Database Feature Source Cordiante
System
Kenneth, GEOGRAF A/S
ks at geograf.dk
Tue May 29 09:09:25 EDT 2007
Oh, my fault. It takes the two coorner coordinates, not a center coordinate.
You must enter correct coordinates in the "lower left" and "upper right"
boxes.
You must also select the correct coordinate system.
When you create a new layer, you must select a datasource.
After selecting the data source, the names of the tables in the
datasource should display in the combo box "Feature class".
You can select the desired table here.
You can select the column containing the geometry in the combobox
"Geometry".
Regards, Kenneth, GEOGRAF A/S
Dhirendra Kumar wrote:
> Hi Kenneth,
> First i want to give you thankyou for your quick replay. Acording to you
> when i go to create Layer then i can view only Data resource used in this
> layer field and select saved Datasource name and i save this layer as a
> same name of Datasource But i am not getting tables name individually and
> after that i make map using this layer then i can view only Coordinate
> system option and initial view option for initial Zoom setting option But i
> am not getting any option for center coordinate. For Information i am using
> MGOS 1.1.0, MySQL 5.0 and Autodesk mapguide studio 2007.So please help me.
> Regards,
> Dhirendra Kumar
> Kenneth, GEOGRAF A/S wrote:
>> You cannot see the tables on the datasource. That is by design. The
>> tables are considered schema's within the datasource.
>> You should be able to see all the tables, when you are creating the layer.
>> When working with databases, I would recommend not using any non-english
>> charaters, even though the database supports it. Many third-party
>> applications break when they encounter such characters.
>> Did you enter the center coordinate on the map?
>> Try looking at the MapGuide log files. They should be in
>> C:\Program Files\MapGuideOpenSource\Server\Logs
>> There might be a message if something went wrong.
>>> Hi Kenneth,
>>> As per your suggestion first i create one datasource (Connection was
>>> succesfull) and after that create layer with existing datasource, and
>>> also
>>> create map and mention cordinate system. But my problem is still same. In
>>> MySQL Database one table with 15 fields and i want to create Points on
>>> field
>>> Longitude and Latitude. Any problem in this field name ? During creation
>>> of
>>> datasource, not getting any option to select any specific table but when
>>> i
>>> use join feature then i can view all tables name for join purpose. Help
>>> me......
>>> Regards,
>>> Dhirendra Kumar
>>>> As Dave wrote, you must zoom in to the data.
>>>> Since you cannot enter coordinates on the layer preview, it will not
>>>> show.
>>>> To view data you must:
>>>> Create a datasource.
>>>> Create a layer with the datasource.
>>>> Create a map.
>>>> Select the coordinate system.
>>>> Specify the center coordinate manually.
>>>> Add the layer.
>>>> Press refresh.
>>>> If it still won't show, doublecheck the connection on the datasource,
>>>> and press the "Test connection" button.
>>>>> Hi Dave,
>>>>> You are right, not any fied in autodesk studio 2007 for mention
>>>>> cordinate
>>>>> system but when i am creating layer using data source, then why Layer
>>>>> is
>>>>> not
>>>>> showing in map preview window of Autodesk studio 2007. Please help me
>>>>> ....... Thankyou in Advance.
>>>>> Regards,
>>>>> Dhirendra Kumar
>>>>> Dave Wilson-3 wrote:
>>>>>> As per my previous email unless you have the new MGOS beta there is no
>>>>>> field to specify a coordinate system override since currently MySQL
>>>>>> doesn't support coordinate systems in the native schema. You can
>>>>>> specify
>>>>>> the correct coordinate system in your map but you will have to zoom
>>>>>> and
>>>>>> find the data to set the extent yourself.
>>>>>> Regards,
>>>>>> Dave
>>>>>> -----Original Message-----
>>>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra
>>>>>> Kumar
>>>>>> Sent: Monday, May 28, 2007 5:07 AM
>>>>>> To: mapguide-users at lists.osgeo.org
>>>>>> Subject: [mapguide-users] MySQL Database Feature Source Cordiante
>>>>>> System
>>>>>> Hi All,
>>>>>> I have successfully established connection of MySQL 5.0 Database and
>>>>>> mapguide 1.1.0 with the help of Autodesk MapGuide Studio 2007 but when
>>>>>> creating Layer using this data source then layer is not showing in
>>>>>> autodesk
>>>>>> Layer Preview window, I think this is happning due to cordinate
>>>>>> system,
>>>>>> If i
>>>>>> am right then where is option of providing cordinate system of MySQL
>>>>>> data
>>>>>> source ? If i am wrong then please give me idea, How to solve this
>>>>>> problem ?
>>>>>> Regards,
>>>>>> Dhirendra Kumar
>>>>>> View this message in context:
>>>>>> http://www.nabble.com/MySQL-Database-Feature-Source-Cordiante-System-tf3
>>>>>> 827380s16610.html#a10834515
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070529/f0d93a26/attachment.html
