[MapServer-dev] RFC-140 - MapServer Homepage
    Seth G
    sethg at geographika.co.uk
    Sat Sep 20 01:01:26 PDT 2025
Hi devs,
I've created an initial PR with the RFC MapServer Homepage implementation at https://github.com/MapServer/MapServer/pull/7350
You can see a live demo of the feature at https://lobster-app-zx7gg.ondigitalocean.app/ and draft documentation at https://geographika.github.io/MapServer-documentation/output/index-page.html.
Please let me know your thoughts, and we can discuss further at the OSGeo Codeprint at the end of the month in Riga,
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Thu, Jul 3, 2025, at 10:29 AM, Seth G via MapServer-dev wrote:
> Hi devs,
> I have been prototyping the MapServer Homepage, and the design has
> evolved since the initial RFC.
> I've mocked up the JSON and HTML template outputs, using the same theme
> as the current MapServer OGC API. The API will be divided into two
> levels - a top-level landing page, and individual landing pages for
> each Mapfile. The JSON approach aims to be compatible with the IETF API
> Catalog specification.
> 1. Landing Page: https://geographika.github.io/mapserver-templates/ and
> https://geographika.github.io/mapserver-templates/api-catalog.json
> I have just included the map file name and alias from the CONFIG file
> found at
> https://github.com/geographika/mapserver-templates/blob/main/mapfiles/mapserver.conf
> Opening all Mapfiles for the landing page could become very slow with
> 100s of Mapfiles, but could be possible if we wanted to take a title
> rather than using a Mapfile filename.
> 2. Individual Mapfile Landing Pages:
> https://geographika.github.io/mapserver-templates/kitchensink/ and
> https://geographika.github.io/mapserver-templates/kitchensink/api-catalog.json
> This will list all available services within the Mapfile. The
> "Kitchensink" demo has everything available - OGC Features, WMS, WFS,
> and WCS. Note as this is a mock-up the links don't actually return
> GetCapabilities files at the moment.
> I have not yet included SOS (and possible CGI services). Again only
> minimal details are shown - adding data such as layers and extents
> seems redundant as a user can drill down into the GetCapabilities or
> OGC API Landing Page to get these details. A brief summary of the
> Mapfile (name, abstract etc.) could be included as metadata? We'd need
> to decide on precedence as these details could be configured
> differently for different services e.g. OGC Features API could use a
> different abstract than WMS.
> Sample Mapfiles on which these services are based can be seen at
> https://github.com/geographika/mapserver-templates/tree/main/mapfiles
> Please let me know your thoughts and comments on the above. If there
> are no objections to the changes I'll update the RFC and continue with
> development. I think "Landing Page" may be the best term to use, as
> this follows the OGC APIs terminology. As the design has changed from
> the initial RFC does this require a new vote?
> Seth
> On Tue, Mar 18, 2025, at 1:18 AM, Daniel Morissette wrote:
>> I like the idea of using PATH_INFO to control this, and "index" sounds
>> like a good option as the default value as you suggested. I'm also fine
>> with picking from the other names that were suggested.
>> On 2025-03-13 06:22, Seth G wrote:
>>> Thanks all for the votes and feedback.
>>> I'm not sure why I went with the ?mode=config&f=json approach - using
>>> the URL path would be a better fit, as I'm trying to follow the OGC API
>>> approach as much as possible. Allowing Mapfile references in the index
>>> was added in [1].
>>> Daniel - I agree "config" could be confusing, and may be better used for
>>> working with the CONFIG directly. I'm now no longer that keen on
>>> "homepage" either! Maybe "index" would be a better fit, similar to the
>>> root of a website defaulting to index.html.
>>> Alternatively, I've just been testing out allowing the homepage/index at
>>> the root of MapServer, if the MS_HOMEPAGE_TEMPLATE_DIRECTORY is set. The
>>> index would then be returned with an empty URL such as
>>> http://localhost/mapserver/ <http://localhost/mapserver/>. This would
>>> also avoid returning the "loadParams(): Web application error. No query
>>> information to decode. QUERY_STRING is set, but empty. " message.
>>> [1] https://github.com/MapServer/MapServer/pull/6862 <https://
>>> github.com/MapServer/MapServer/pull/6862>
>>> web:https://geographika.net <https://geographika.net> & https://
>>> mapserverstudio.net <https://mapserverstudio.net>
>>> mastodon: @geographika at mastodon.social <mailto:geographika at mastodon.social>
>>> On Tue, Mar 11, 2025, at 5:46 PM, Lime, Steve D (MNIT) via MapServer-dev
>>> wrote:
>>>> The path after the binary name is available to you through an
>>>> environment variable (PATH_INFO) as part of normal web server
>>>> processing. We leverage that for OGC API support. In this case, you’d
>>>> just look at the first component of the PATH_INFO and see if it
>>>> matches your keyword (e.g. homepage) and then process accordingly (if
>>>> enabled). Otherwise the first component of PATH_INFO is interpreted as
>>>> the mapfile (more typically the mapfile alias) – Seth added that
>>>> support in 8.2 (I think).
>>>> *From:*Richard Greenwood <richard.greenwood at gmail.com>
>>>> *Sent:* Tuesday, March 11, 2025 11:35 AM
>>>> *To:* Lime, Steve D (MNIT) <steve.lime at state.mn.us>
>>>> *Cc:* Daniel Morissette <dmorissette at mapgears.com>; mapserver-
>>>> dev at lists.osgeo.org
>>>> *Subject:* Re: [MapServer-dev] RFC-140 - MapServer Homepage
>>>> On Tue, Mar 11, 2025 at 8:47 AM Lime, Steve D (MNIT) via MapServer-dev
>>>> <mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>>
>>>> wrote:
>>>>     One idea might be to support a more restful URL, e.g. https://
>>>>     myhost.com/cgi-bin/mapserv/homepage <https://myhost.com/cgi-bin/
>>>>     mapserv/homepage> (or /home or /index or ?) instead of using a
>>>>     parameter-based approach. Maybe that endpoint name could be
>>>>     configurable via the config file –  and that could also enable the
>>>>     functionality.
>>>>  Steve, correct me if I'm wrong, but that seems like it's getting into
>>>> the realm of the web server. Like how is the mapserv binary to know
>>>> that it should look for, and process, stuff after the "/"? What
>>>> happens for example with "cgi-bin/mapserv.fcgi/homepage"? Does Apache
>>>> know that I want to run the mapserv binary in fcgi mode and also know
>>>> to pass the "homepage" part to the binary as a parameter? I like the
>>>> idea of a restful syntax but I can't get my head around the
>>>> implementation.
>>>> Rich
>>>>     *From:*MapServer-dev <mapserver-dev-bounces at lists.osgeo.org
>>>>     <mailto:mapserver-dev-bounces at lists.osgeo.org>> *On Behalf Of
>>>>     *Daniel Morissette via MapServer-dev
>>>>     *Sent:* Monday, March 10, 2025 4:58 PM
>>>>     *To:* mapserver-dev at lists.osgeo.org <mailto:mapserver-
>>>>     Hi everyone,
>>>>     Sorry for being late with my feedback.  I like the RFC overall,
>>>>     but was wondering if we could find a better trigger than
>>>>     mode=config for this feature.  My first reaction when I saw
>>>>     mode=config was that this mode could be used to deal with the
>>>>     actual config settings in the future if we ever want to go there
>>>>     so using mode=config today for this homepage feature could limit
>>>>     our future options.  That being said, I couldn't find any good
>>>>     names other than mode=homepage to match the
>>>>     MS_HOMEPAGE_TEMPLATE_DIRECTORY variable that controls it.
>>>>     I can live with mode=config if we have no better option and am +1
>>>>     with the RFC otherwise.
>>>>     Daniel
>>>>     On 2025-03-09 11:57, Seth G via MapServer-dev wrote:
>>>>         Hi all,
>>>>         I've added in the feedback from the comments above to RFC 140
>>>>         [1], see diff of changes at [2].
>>>>         I'd like to now formally propose to adopt this RFC, starting
>>>>         with my +1.
>>>>         Seth
>>>>         [1] https://mapserver.org/development/rfc/ms-rfc-140.html
>>>>         <https://mapserver.org/development/rfc/ms-rfc-140.html>
>>>>         [2] https://github.com/MapServer/MapServer-documentation/
>>>>         pull/1000/files <https://github.com/MapServer/MapServer-
>>>>         documentation/pull/1000/files>
>>>>         web:https://geographika.net <https://geographika.net/> &
>>>>         https://mapserverstudio.net <https://mapserverstudio.net/>
>>>>         On Wed, Jan 22, 2025, at 4:40 PM, Tom Kralidis wrote:
>>>>             Thanks Seth.
>>>>             RE: service-meta: I would still keep to the link
>>>>             conventions (proper media type for "type", we could add a
>>>>             custom "service-type=WMS" property), and include an href
>>>>             as well.
>>>>             ..Tom
>>>>             On Wed, Jan 22, 2025 at 10:27 AM Seth G
>>>>             <sethg at geographika.co.uk <mailto:sethg at geographika.co.uk>>
>>>>             wrote:
>>>>                 Thanks Tom - that pygeoapi pull request is good timing!
>>>>                 After reviewing and reading some of the associated
>>>>                 documents, I'm planning to update the RFC with the
>>>>                 notes below.
>>>>                 pygeoapi has implemented a JSON service for their
>>>>                 homepage at [1] (pull request at [2].
>>>>                 This implements the api-catalog, a draft IETF
>>>>                 (Internet Engineering Task Force) standard [3].
>>>>                 The Link Set format is described at [4]. It is
>>>>                 proposed this approach is used to generate JSON for a
>>>>                 MapServer "homepage".
>>>>                 The generated JSON format can be seen at https://
>>>>                 demo.pygeoapi.io/api-catalog.json <https://
>>>>                 demo.pygeoapi.io/api-catalog.json>, with an extract below:
>>>>                   "linkset": [
>>>>                       "anchor": "https://demo.pygeoapi.io/master
>>>>                 <https://demo.pygeoapi.io/master>",
>>>>                       "service-desc": [
>>>>                           "href": "https://demo.pygeoapi.io/master/
>>>>                 openapi?f=json <https://demo.pygeoapi.io/master/
>>>>                 openapi?f=json>",
>>>>                           "title": "pygeoapi - latest GitHub 'master'
>>>>                 version (JSON)",
>>>>                           "type": "application/vnd.oai.openapi+json"
>>>>                       "service-doc": [
>>>>                 openapi?f=html <https://demo.pygeoapi.io/master/
>>>>                 openapi?f=html>",
>>>>                 version (HTML)",
>>>>                           "type": "text/html"
>>>>                 The spec allows for an additional "service-meta"
>>>>                 property "used to link to additional metadata about
>>>>                 the API,
>>>>                 and is primarily intended for machine consumption." I
>>>>                 think this can be used to add any additional
>>>>                 properties from Mapfiles
>>>>                 we'd need to generate a MapServer homepage.
>>>>                 "service-doc" isn't mandatory, so WxS service links
>>>>                 can ignore this. An example of the proposed JSON and
>>>>                 metadata is shown below:
>>>>                   "linkset": [
>>>>                       "anchor": "https://demo.mapserver.org/ <https://
>>>>                 demo.mapserver.org/>",
>>>>                       "service-desc": [
>>>>                           "href": "https://demo.mapserver.org/cgi-bin/
>>>>                 msautotest?
>>>>                 SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>>                 <https://demo.mapserver.org/cgi-bin/msautotest?
>>>>                 SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>",
>>>>                           "title": "World WMS service",
>>>>                           "type": "text/xml"
>>>>                       "service-meta": {
>>>>                            "type": "wms",
>>>>                            "title": "WMS demo server for MapServer,
>>>>                 used in the msautotest suite",
>>>>                            "keywords": ["layers", "list"],
>>>>                            "mapfile": "msautotest.map",
>>>>                 Seth
>>>>                 [1] https://demo.pygeoapi.io/ <https://demo.pygeoapi.io/>
>>>>                 [2] https://github.com/geopython/demo.pygeoapi.io/
>>>>                 pull/60/files <https://github.com/geopython/
>>>>                 demo.pygeoapi.io/pull/60/files>
>>>>                 [3] https://datatracker.ietf.org/doc/draft-ietf-
>>>>                 httpapi-api-catalog/08/ <https://datatracker.ietf.org/
>>>>                 doc/draft-ietf-httpapi-api-catalog/08/>
>>>>                 [4] https://www.rfc-editor.org/rfc/rfc9264.html
>>>>                 <https://www.rfc-editor.org/rfc/rfc9264.html>
>>>>                 & https://mapserverstudio.net <https://
>>>>                 On Sun, Jan 19, 2025, at 5:10 PM, Tom Kralidis wrote:
>>>>                     Seth: thanks for this RFC.  IETF has  api-catalog
>>>>                     (draft, [1]) which I think would be a good
>>>>                     candidate for this RFC.  This is also an item for
>>>>                     review in the OGC API - Records SWG [2].
>>>>                     Overall it looks pretty close to the RFC
>>>>                     proposal.  We can consider using api-catalog as a
>>>>                     baseline and we can extend the JSON accordingly as
>>>>                     needed for anything specific to our needs.
>>>>                     Cheers
>>>>                     ..Tom
>>>>                     [1] https://datatracker.ietf.org/doc/draft-ietf-
>>>>                     httpapi-api-catalog <https://datatracker.ietf.org/
>>>>                     doc/draft-ietf-httpapi-api-catalog>
>>>>                     [2] https://github.com/opengeospatial/ogcapi-
>>>>                     records/issues/355 <https://github.com/
>>>>                     opengeospatial/ogcapi-records/issues/355>
>>>>                     On Sat, Jan 18, 2025 at 5:39 PM Seth G via
>>>>                     MapServer-dev <mapserver-dev at lists.osgeo.org
>>>>                     <mailto:mapserver-dev at lists.osgeo.org>> wrote:
>>>>                         Looking again at the landing page JSON at
>>>>                         https://demo.mapserver.org/cgi-bin/mapserv/
>>>>                         localdemo/ogcapi?f=json <https://
>>>>                         demo.mapserver.org/cgi-bin/mapserv/localdemo/
>>>>                         ogcapi?f=json> it is in the same format, so as
>>>>                         you suggested could simply be expanded with
>>>>                         links to WxS services, or even CGI generated
>>>>                         responses. This would also more easily allow
>>>>                         template reuse.
>>>>                         Seth
>>>>                         geographika.net/> & https://
>>>>                         On Sat, Jan 18, 2025, at 11:33 PM, Seth G via
>>>>                         > Hi Even,
>>>>                         > Thanks for your valuable feedback.
>>>>                         > The homepage would be a "superset" of all
>>>>                         available Mapfiles in a
>>>>                         > MapServer deployment, as listed in the
>>>>                         CONFIG file. Each individual
>>>>                         > Mapfile would still have its own OGC API
>>>>                         landing page, so the homepage
>>>>                         > is best described as a directory of all
>>>>                         landing pages.
>>>>                         > As most MapServer deployments will likely be
>>>>                         serving out a combination
>>>>                         > of WxS and new OGC API services for some
>>>>                         time to come, it will allow
>>>>                         > both types to be listed together (I'm
>>>>                         unaware of a OGC API spec that
>>>>                         > would cover this).
>>>>                         > In regard to the JSON used for links, I was
>>>>                         modelling it as closely as
>>>>                         > possible to OGC API conventions. Looking at
>>>>                         the pygeoapi demo home
>>>>                         > page, it provides a set of links in a common
>>>>                         format, so I'll likely
>>>>                         > switch to this format/approach:
>>>>                         > https://demo.pygeoapi.io/stable?f=json
>>>>                         <https://demo.pygeoapi.io/stable?f=json>
>>>>                         > A few of the "rel" values are defined as
>>>>                         below, and can be reused:
>>>>                         > alternate     Provides an alternate
>>>>                         representation (e.g., HTML version of a
>>>>                         > resource).
>>>>                         > service-desc  Links to the machine-readable
>>>>                         API description (e.g.,
>>>>                         > OpenAPI JSON).
>>>>                         > service-doc   Links to the human-readable
>>>>                         API documentation (e.g.,
>>>>                         > OpenAPI HTML).
>>>>                         > conformance   Lists the standards and
>>>>                         conformance classes supported by
>>>>                         > the API.
>>>>                         > I'll update the RFC with the above,
>>>>                         > Seth
>>>>                         > On Sat, Jan 18, 2025, at 12:39 PM, Even
>>>>                         Rouault wrote:
>>>>                         >> Seth,
>>>>                         >> Thanks for putting this together. I'm
>>>>                         wondering how much your proposal
>>>>                         >> relates/intersects with the concept of the
>>>>                         landing page of OGC API
>>>>                         >> services ? You mention some connection with
>>>>                         it, but it is not
>>>>                         >> immediately clear to me  the exact nature
>>>>                         of the connection. Perhaps it
>>>>                         >> is just a matter of clarifying. I have put
>>>>                         zero thoughts in it, but it
>>>>                         >> would feel weird to invent a MapServer
>>>>                         specific thing, so I'm naively
>>>>                         >> wondering if we can't we just adopt the
>>>>                         landing page formalism (for the
>>>>                         >> JSON part), and potentially extend it by
>>>>                         exposing old WxS services as
>>>>                         >> well in the links as you suggest? I'm also
>>>>                         wondering if there's some
>>>>                         >> best practice used by other projects on how
>>>>                         to expose for things like
>>>>                         >>              "href":
>>>>                         >> "https://demo.mapserver.org/cgi-bin/wms?
>>>>                         SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities <https://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>",
>>>>                         >>              "title": "GetCapabilities",
>>>>                         >>              "type": "WMS"
>>>>                         >> so they can be interoperably consumed.
>>>>                         >> Even
>>>>                         >> Le 18/01/2025 à 09:11, Seth G via
>>>>                         MapServer-dev a écrit :
>>>>                         >>> Hi devs,
>>>>                         >>> I've drafted an RFC with an approach of
>>>>                         creating a MapServer homepage based on the
>>>>                         MAPs referenced in a mapserver.conf file. This
>>>>                         will allow MapServer installations to easily
>>>>                         advertise available services, dynamically.
>>>>                         >>> Text available in pull request at https://
>>>>                         pull/996 <https://github.com/MapServer/
>>>>                         MapServer-documentation/pull/996>
>>>>                         >>> Comments and thoughts appreciated,
>>>>                         >>> Thanks,
>>>>                         >>> Seth
>>>>                         _______________________________________________
>>>>                         >>> MapServer-dev mailing list
>>>>                         >>> MapServer-dev at lists.osgeo.org
>>>>                         <mailto:MapServer-dev at lists.osgeo.org>
>>>>                         >>> https://lists.osgeo.org/mailman/listinfo/
>>>>                         mapserver-dev <https://lists.osgeo.org/
>>>>                         mailman/listinfo/mapserver-dev>
>>>>                         >> http://www.spatialys.com <http://
>>>>                         www.spatialys.com/>
>>>>                         >> My software is free, but my time generally not.
>>>>                         >> Butcher of all kinds of standards, open or
>>>>                         closed formats. At the end,
>>>>                         >> this is just about bytes.
>>>>         MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>
>>>>         https://lists.osgeo.org/mailman/listinfo/mapserver-dev <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>>>>     Daniel Morissette
>>>>     Mapgears Inc
>>>>     T: +1 418-696-5056 #201
>>>> Richard W. Greenwood
>>>> www.greenwoodmap.com <http://www.greenwoodmap.com/>
>> Daniel Morissette
>> Mapgears Inc
More information about the MapServer-dev
