[MapServer-dev] RFC-140 - MapServer Homepage
Michael Smith
michael.smith.erdc at gmail.com
Sat Sep 20 04:18:20 PDT 2025
Seth,
I like this a lot, I think this has been needed for a while now. One thing I've found is that the query param don't always trigger the json. If I go one level deep and then click a json like, for example https://lobster-app-zx7gg.ondigitalocean.app/OGCAPI_MAP/?OGCAPI_MAP/?f=json, I don't get the json page, I get HTML. Other than that, I'm 100% behind this.
Mike
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
On 9/20/25, 4:01 AM, "MapServer-dev on behalf of Seth G via MapServer-dev" <mapserver-dev-bounces at lists.osgeo.org <mailto:mapserver-dev-bounces at lists.osgeo.org> on behalf of mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>> wrote:
Hi devs,
I've created an initial PR with the RFC MapServer Homepage implementation at https://github.com/MapServer/MapServer/pull/7350 <https://github.com/MapServer/MapServer/pull/7350>
You can see a live demo of the feature at https://lobster-app-zx7gg.ondigitalocean.app/ <https://lobster-app-zx7gg.ondigitalocean.app/> and draft documentation at https://geographika.github.io/MapServer-documentation/output/index-page.html <https://geographika.github.io/MapServer-documentation/output/index-page.html>.
Please let me know your thoughts, and we can discuss further at the OSGeo Codeprint at the end of the month in Riga,
Seth
web:https://geographika.net <https://geographika.net> & https://mapserverstudio.net <https://mapserverstudio.net>
mastodon: @geographika at mastodon.soci <mailto:geographika at mastodon.soci>al
On Thu, Jul 3, 2025, at 10:29 AM, Seth G via MapServer-dev wrote:
> Hi devs,
> I have been prototyping the MapServer Homepage, and the design has
> evolved since the initial RFC.
> I've mocked up the JSON and HTML template outputs, using the same theme
> as the current MapServer OGC API. The API will be divided into two
> levels - a top-level landing page, and individual landing pages for
> each Mapfile. The JSON approach aims to be compatible with the IETF API
> Catalog specification.
> 1. Landing Page: https://geographika.github.io/mapserver-templates/ <https://geographika.github.io/mapserver-templates/> and
> https://geographika.github.io/mapserver-templates/api-catalog.json <https://geographika.github.io/mapserver-templates/api-catalog.json>
> I have just included the map file name and alias from the CONFIG file
> found at
> https://github.com/geographika/mapserver-templates/blob/main/mapfiles/mapserver.conf <https://github.com/geographika/mapserver-templates/blob/main/mapfiles/mapserver.conf>
> Opening all Mapfiles for the landing page could become very slow with
> 100s of Mapfiles, but could be possible if we wanted to take a title
> rather than using a Mapfile filename.
> 2. Individual Mapfile Landing Pages:
> https://geographika.github.io/mapserver-templates/kitchensink/ <https://geographika.github.io/mapserver-templates/kitchensink/> and
> https://geographika.github.io/mapserver-templates/kitchensink/api-catalog.json <https://geographika.github.io/mapserver-templates/kitchensink/api-catalog.json>
> This will list all available services within the Mapfile. The
> "Kitchensink" demo has everything available - OGC Features, WMS, WFS,
> and WCS. Note as this is a mock-up the links don't actually return
> GetCapabilities files at the moment.
> I have not yet included SOS (and possible CGI services). Again only
> minimal details are shown - adding data such as layers and extents
> seems redundant as a user can drill down into the GetCapabilities or
> OGC API Landing Page to get these details. A brief summary of the
> Mapfile (name, abstract etc.) could be included as metadata? We'd need
> to decide on precedence as these details could be configured
> differently for different services e.g. OGC Features API could use a
> different abstract than WMS.
> Sample Mapfiles on which these services are based can be seen at
> https://github.com/geographika/mapserver-templates/tree/main/mapfiles <https://github.com/geographika/mapserver-templates/tree/main/mapfiles>
> Please let me know your thoughts and comments on the above. If there
> are no objections to the changes I'll update the RFC and continue with
> development. I think "Landing Page" may be the best term to use, as
> this follows the OGC APIs terminology. As the design has changed from
> the initial RFC does this require a new vote?
> Seth
> On Tue, Mar 18, 2025, at 1:18 AM, Daniel Morissette wrote:
>> I like the idea of using PATH_INFO to control this, and "index" sounds
>> like a good option as the default value as you suggested. I'm also fine
>> with picking from the other names that were suggested.
>> On 2025-03-13 06:22, Seth G wrote:
>>> Thanks all for the votes and feedback.
>>> I'm not sure why I went with the ?mode=config&f=json approach - using
>>> the URL path would be a better fit, as I'm trying to follow the OGC API
>>> approach as much as possible. Allowing Mapfile references in the index
>>> was added in [1].
>>> Daniel - I agree "config" could be confusing, and may be better used for
>>> working with the CONFIG directly. I'm now no longer that keen on
>>> "homepage" either! Maybe "index" would be a better fit, similar to the
>>> root of a website defaulting to index.html.
>>> Alternatively, I've just been testing out allowing the homepage/index at
>>> the root of MapServer, if the MS_HOMEPAGE_TEMPLATE_DIRECTORY is set. The
>>> index would then be returned with an empty URL such as
>>> http://localhost/mapserver/ <http://localhost/mapserver/>. This would
>>> also avoid returning the "loadParams(): Web application error. No query
>>> information to decode. QUERY_STRING is set, but empty. " message.
>>> [1] https://github.com/MapServer/MapServer/pull/6862 <https://github.com/MapServer/MapServer/pull/6862> <https://
>>> web:https://geographika.net <https://geographika.net> <https://geographika.net> <https://geographika.net>> & https://
>>> mapserverstudio.net <https://mapserverstudio.net> <https://mapserverstudio.net>>
>>> mastodon: @geographika at mastodon.soci <mailto:geographika at mastodon.soci>al <mailto:geographika at mastodon.soci <mailto:geographika at mastodon.soci>al>
>>> On Tue, Mar 11, 2025, at 5:46 PM, Lime, Steve D (MNIT) via MapServer-dev
>>> wrote:
>>>> The path after the binary name is available to you through an
>>>> environment variable (PATH_INFO) as part of normal web server
>>>> processing. We leverage that for OGC API support. In this case, you’d
>>>> just look at the first component of the PATH_INFO and see if it
>>>> matches your keyword (e.g. homepage) and then process accordingly (if
>>>> enabled). Otherwise the first component of PATH_INFO is interpreted as
>>>> the mapfile (more typically the mapfile alias) – Seth added that
>>>> support in 8.2 (I think).
>>>> *From:*Richard Greenwood <richard.greenwood at gmail.com <mailto:richard.greenwood at gmail.com>>
>>>> *Sent:* Tuesday, March 11, 2025 11:35 AM
>>>> *To:* Lime, Steve D (MNIT) <steve.lime at state.mn.us <mailto:steve.lime at state.mn.us>>
>>>> *Cc:* Daniel Morissette <dmorissette at mapgears.com <mailto:dmorissette at mapgears.com>>; mapserver-
>>>> dev at lists.osgeo.org <mailto:dev at lists.osgeo.org>
>>>> *Subject:* Re: [MapServer-dev] RFC-140 - MapServer Homepage
>>>> On Tue, Mar 11, 2025 at 8:47 AM Lime, Steve D (MNIT) via MapServer-dev
>>>> <mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org> <mailto:mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>>>
>>>> wrote:
>>>> One idea might be to support a more restful URL, e.g. https://
>>>> myhost.com/cgi-bin/mapserv/homepage <https://myhost.com/cgi-bin/ <https://myhost.com/cgi-bin/>
>>>> mapserv/homepage> (or /home or /index or ?) instead of using a
>>>> parameter-based approach. Maybe that endpoint name could be
>>>> configurable via the config file – and that could also enable the
>>>> functionality.
>>>> Steve, correct me if I'm wrong, but that seems like it's getting into
>>>> the realm of the web server. Like how is the mapserv binary to know
>>>> that it should look for, and process, stuff after the "/"? What
>>>> happens for example with "cgi-bin/mapserv.fcgi/homepage"? Does Apache
>>>> know that I want to run the mapserv binary in fcgi mode and also know
>>>> to pass the "homepage" part to the binary as a parameter? I like the
>>>> idea of a restful syntax but I can't get my head around the
>>>> implementation.
>>>> Rich
>>>> *From:*MapServer-dev <mapserver-dev-bounces at lists.osgeo.org <mailto:mapserver-dev-bounces at lists.osgeo.org>
>>>> <mailto:mapserver-dev-bounces at lists.osgeo.org <mailto:mapserver-dev-bounces at lists.osgeo.org>>> *On Behalf Of
>>>> *Daniel Morissette via MapServer-dev
>>>> *Sent:* Monday, March 10, 2025 4:58 PM
>>>> *To:* mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org> <mailto:mapserver-
>>>> dev at lists.osgeo.org <mailto:dev at lists.osgeo.org>>
>>>> Hi everyone,
>>>> Sorry for being late with my feedback. I like the RFC overall,
>>>> but was wondering if we could find a better trigger than
>>>> mode=config for this feature. My first reaction when I saw
>>>> mode=config was that this mode could be used to deal with the
>>>> actual config settings in the future if we ever want to go there
>>>> so using mode=config today for this homepage feature could limit
>>>> our future options. That being said, I couldn't find any good
>>>> names other than mode=homepage to match the
>>>> MS_HOMEPAGE_TEMPLATE_DIRECTORY variable that controls it.
>>>> I can live with mode=config if we have no better option and am +1
>>>> with the RFC otherwise.
>>>> Daniel
>>>> On 2025-03-09 11:57, Seth G via MapServer-dev wrote:
>>>> Hi all,
>>>> I've added in the feedback from the comments above to RFC 140
>>>> [1], see diff of changes at [2].
>>>> I'd like to now formally propose to adopt this RFC, starting
>>>> with my +1.
>>>> Seth
>>>> [1] https://mapserver.org/development/rfc/ms-rfc-140.html <https://mapserver.org/development/rfc/ms-rfc-140.html>
>>>> <https://mapserver.org/development/rfc/ms-rfc-140.html> <https://mapserver.org/development/rfc/ms-rfc-140.html>>
>>>> [2] https://github.com/MapServer/MapServer-documentation/ <https://github.com/MapServer/MapServer-documentation/>
>>>> pull/1000/files <https://github.com/MapServer/MapServer- <https://github.com/MapServer/MapServer->
>>>> documentation/pull/1000/files>
>>>> web:https://geographika.net <https://geographika.net> <https://geographika.net/> <https://geographika.net/>> &
>>>> https://mapserverstudio.net <https://mapserverstudio.net> <https://mapserverstudio.net/> <https://mapserverstudio.net/>>
>>>> On Wed, Jan 22, 2025, at 4:40 PM, Tom Kralidis wrote:
>>>> Thanks Seth.
>>>> RE: service-meta: I would still keep to the link
>>>> conventions (proper media type for "type", we could add a
>>>> custom "service-type=WMS" property), and include an href
>>>> as well.
>>>> ..Tom
>>>> On Wed, Jan 22, 2025 at 10:27 AM Seth G
>>>> <sethg at geographika.co.uk <mailto:sethg at geographika.co.uk> <mailto:sethg at geographika.co.uk <mailto:sethg at geographika.co.uk>>>
>>>> wrote:
>>>> Thanks Tom - that pygeoapi pull request is good timing!
>>>> After reviewing and reading some of the associated
>>>> documents, I'm planning to update the RFC with the
>>>> notes below.
>>>> pygeoapi has implemented a JSON service for their
>>>> homepage at [1] (pull request at [2].
>>>> This implements the api-catalog, a draft IETF
>>>> (Internet Engineering Task Force) standard [3].
>>>> The Link Set format is described at [4]. It is
>>>> proposed this approach is used to generate JSON for a
>>>> MapServer "homepage".
>>>> The generated JSON format can be seen at https://
>>>> demo.pygeoapi.io/api-catalog.json <https://
>>>> demo.pygeoapi.io/api-catalog.json>, with an extract below:
>>>> "linkset": [
>>>> "anchor": "https://demo.pygeoapi.io/master <https://demo.pygeoapi.io/master>
>>>> <https://demo.pygeoapi.io/master>" <https://demo.pygeoapi.io/master>">,
>>>> "service-desc": [
>>>> "href": "https://demo.pygeoapi.io/master/ <https://demo.pygeoapi.io/master/>
>>>> openapi?f=json <https://demo.pygeoapi.io/master/ <https://demo.pygeoapi.io/master/>
>>>> openapi?f=json>",
>>>> "title": "pygeoapi - latest GitHub 'master'
>>>> version (JSON)",
>>>> "type": "application/vnd.oai.openapi+json"
>>>> "service-doc": [
>>>> openapi?f=html <https://demo.pygeoapi.io/master/ <https://demo.pygeoapi.io/master/>
>>>> openapi?f=html>",
>>>> version (HTML)",
>>>> "type": "text/html"
>>>> The spec allows for an additional "service-meta"
>>>> property "used to link to additional metadata about
>>>> the API,
>>>> and is primarily intended for machine consumption." I
>>>> think this can be used to add any additional
>>>> properties from Mapfiles
>>>> we'd need to generate a MapServer homepage.
>>>> "service-doc" isn't mandatory, so WxS service links
>>>> can ignore this. An example of the proposed JSON and
>>>> metadata is shown below:
>>>> "linkset": [
>>>> "anchor": "https://demo.mapserver.org/ <https://demo.mapserver.org/> <https://
>>>> demo.mapserver.org/>",
>>>> "service-desc": [
>>>> "href": "https://demo.mapserver.org/cgi-bin/ <https://demo.mapserver.org/cgi-bin/>
>>>> msautotest?
>>>> SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>> <https://demo.mapserver.org/cgi-bin/msautotest? <https://demo.mapserver.org/cgi-bin/msautotest?>
>>>> SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>",
>>>> "title": "World WMS service",
>>>> "type": "text/xml"
>>>> "service-meta": {
>>>> "type": "wms",
>>>> "title": "WMS demo server for MapServer,
>>>> used in the msautotest suite",
>>>> "keywords": ["layers", "list"],
>>>> "mapfile": "msautotest.map",
>>>> Seth
>>>> [1] https://demo.pygeoapi.io/ <https://demo.pygeoapi.io/> <https://demo.pygeoapi.io/> <https://demo.pygeoapi.io/>>
>>>> [2] https://github.com/geopython/demo.pygeoapi.io/ <https://github.com/geopython/demo.pygeoapi.io/>
>>>> pull/60/files <https://github.com/geopython/ <https://github.com/geopython/>
>>>> demo.pygeoapi.io/pull/60/files>
>>>> [3] https://datatracker.ietf.org/doc/draft-ietf- <https://datatracker.ietf.org/doc/draft-ietf->
>>>> httpapi-api-catalog/08/ <https://datatracker.ietf.org/ <https://datatracker.ietf.org/>
>>>> doc/draft-ietf-httpapi-api-catalog/08/>
>>>> [4] https://www.rfc-editor.org/rfc/rfc9264.html <https://www.rfc-editor.org/rfc/rfc9264.html>
>>>> <https://www.rfc-editor.org/rfc/rfc9264.html> <https://www.rfc-editor.org/rfc/rfc9264.html>>
>>>> & https://mapserverstudio.net <https://mapserverstudio.net> <https://
>>>> On Sun, Jan 19, 2025, at 5:10 PM, Tom Kralidis wrote:
>>>> Seth: thanks for this RFC. IETF has api-catalog
>>>> (draft, [1]) which I think would be a good
>>>> candidate for this RFC. This is also an item for
>>>> review in the OGC API - Records SWG [2].
>>>> Overall it looks pretty close to the RFC
>>>> proposal. We can consider using api-catalog as a
>>>> baseline and we can extend the JSON accordingly as
>>>> needed for anything specific to our needs.
>>>> Cheers
>>>> ..Tom
>>>> [1] https://datatracker.ietf.org/doc/draft-ietf- <https://datatracker.ietf.org/doc/draft-ietf->
>>>> httpapi-api-catalog <https://datatracker.ietf.org/ <https://datatracker.ietf.org/>
>>>> doc/draft-ietf-httpapi-api-catalog>
>>>> [2] https://github.com/opengeospatial/ogcapi- <https://github.com/opengeospatial/ogcapi->
>>>> records/issues/355 <https://github.com/ <https://github.com/>
>>>> opengeospatial/ogcapi-records/issues/355>
>>>> On Sat, Jan 18, 2025 at 5:39 PM Seth G via
>>>> MapServer-dev <mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>>>> <mailto:mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>>> wrote:
>>>> Looking again at the landing page JSON at
>>>> https://demo.mapserver.org/cgi-bin/mapserv/ <https://demo.mapserver.org/cgi-bin/mapserv/>
>>>> localdemo/ogcapi?f=json <https://
>>>> demo.mapserver.org/cgi-bin/mapserv/localdemo/
>>>> ogcapi?f=json> it is in the same format, so as
>>>> you suggested could simply be expanded with
>>>> links to WxS services, or even CGI generated
>>>> responses. This would also more easily allow
>>>> template reuse.
>>>> Seth
>>>> geographika.net/> & https://
>>>> mapserverstudio.net <https://mapserverstudio.net/> <https://mapserverstudio.net/>>
>>>> On Sat, Jan 18, 2025, at 11:33 PM, Seth G via
>>>> > Hi Even,
>>>> > Thanks for your valuable feedback.
>>>> > The homepage would be a "superset" of all
>>>> available Mapfiles in a
>>>> > MapServer deployment, as listed in the
>>>> CONFIG file. Each individual
>>>> > Mapfile would still have its own OGC API
>>>> landing page, so the homepage
>>>> > is best described as a directory of all
>>>> landing pages.
>>>> > As most MapServer deployments will likely be
>>>> serving out a combination
>>>> > of WxS and new OGC API services for some
>>>> time to come, it will allow
>>>> > both types to be listed together (I'm
>>>> unaware of a OGC API spec that
>>>> > would cover this).
>>>> > In regard to the JSON used for links, I was
>>>> modelling it as closely as
>>>> > possible to OGC API conventions. Looking at
>>>> the pygeoapi demo home
>>>> > page, it provides a set of links in a common
>>>> format, so I'll likely
>>>> > switch to this format/approach:
>>>> > https://demo.pygeoapi.io/stable?f=json <https://demo.pygeoapi.io/stable?f=json>
>>>> <https://demo.pygeoapi.io/stable?f=json> <https://demo.pygeoapi.io/stable?f=json>>
>>>> > A few of the "rel" values are defined as
>>>> below, and can be reused:
>>>> > alternate Provides an alternate
>>>> representation (e.g., HTML version of a
>>>> > resource).
>>>> > service-desc Links to the machine-readable
>>>> API description (e.g.,
>>>> > OpenAPI JSON).
>>>> > service-doc Links to the human-readable
>>>> API documentation (e.g.,
>>>> > OpenAPI HTML).
>>>> > conformance Lists the standards and
>>>> conformance classes supported by
>>>> > the API.
>>>> > I'll update the RFC with the above,
>>>> > Seth
>>>> > On Sat, Jan 18, 2025, at 12:39 PM, Even
>>>> Rouault wrote:
>>>> >> Seth,
>>>> >> Thanks for putting this together. I'm
>>>> wondering how much your proposal
>>>> >> relates/intersects with the concept of the
>>>> landing page of OGC API
>>>> >> services ? You mention some connection with
>>>> it, but it is not
>>>> >> immediately clear to me the exact nature
>>>> of the connection. Perhaps it
>>>> >> is just a matter of clarifying. I have put
>>>> zero thoughts in it, but it
>>>> >> would feel weird to invent a MapServer
>>>> specific thing, so I'm naively
>>>> >> wondering if we can't we just adopt the
>>>> landing page formalism (for the
>>>> >> JSON part), and potentially extend it by
>>>> exposing old WxS services as
>>>> >> well in the links as you suggest? I'm also
>>>> wondering if there's some
>>>> >> best practice used by other projects on how
>>>> to expose for things like
>>>> >> "href":
>>>> >> "https://demo.mapserver.org/cgi-bin/wms? <https://demo.mapserver.org/cgi-bin/wms?>
>>>> SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities <https://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>" <https://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>">,
>>>> >> "title": "GetCapabilities",
>>>> >> "type": "WMS"
>>>> >> so they can be interoperably consumed.
>>>> >> Even
>>>> >> Le 18/01/2025 à 09:11, Seth G via
>>>> MapServer-dev a écrit :
>>>> >>> Hi devs,
>>>> >>> I've drafted an RFC with an approach of
>>>> creating a MapServer homepage based on the
>>>> MAPs referenced in a mapserver.conf file. This
>>>> will allow MapServer installations to easily
>>>> advertise available services, dynamically.
>>>> >>> Text available in pull request at https://
>>>> pull/996 <https://github.com/MapServer/ <https://github.com/MapServer/>
>>>> MapServer-documentation/pull/996>
>>>> >>> Comments and thoughts appreciated,
>>>> >>> Thanks,
>>>> >>> Seth
>>>> _______________________________________________
>>>> >>> MapServer-dev mailing list
>>>> >>> MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>
>>>> <mailto:MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>>
>>>> >>> https://lists.osgeo.org/mailman/listinfo/ <https://lists.osgeo.org/mailman/listinfo/>
>>>> mapserver-dev <https://lists.osgeo.org/ <https://lists.osgeo.org/>
>>>> mailman/listinfo/mapserver-dev>
>>>> >> http://www.spatialys.com <http://www.spatialys.com> <http://
>>>> www.spatialys.com/>
>>>> >> My software is free, but my time generally not.
>>>> >> Butcher of all kinds of standards, open or
>>>> closed formats. At the end,
>>>> >> this is just about bytes.
>>>> MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org> <mailto:MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>>
>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev <https://lists.osgeo.org/mailman/listinfo/mapserver-dev> <https://lists.osgeo.org/mailman/listinfo/mapserver-dev> <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>>
>>>> Daniel Morissette
>>>> Mapgears Inc
>>>> T: +1 418-696-5056 #201
>>>> Richard W. Greenwood
>>>> www.greenwoodmap.com <http://www.greenwoodmap.com/> <http://www.greenwoodmap.com/>>
>> Daniel Morissette
>> Mapgears Inc
More information about the MapServer-dev
