remove temp files
Jim T. Bowen (GAIA Consultants Inc.)
bowenj at peligroso.gaiaenv.com
Wed May 10 15:21:05 EDT 2000
Here is a little bit more on crontab:
You need to ensure the cron daemon is started. Begin by editing a
crontab entry. This invokes your default text editor (e.g., VI or
emacs). Don't simply edit the crontab file...use the following command:
crontab -e
Enter your parameters in this file. Each line represents a command with
parameters. This example blows away everything in the temp folder daily
at 03:30. You can use wildcards for defaults. Obviously, you should
double check your commands and settings so you don't run a command you
regret!
30 3 * * * rm -rf /home/httpd/temp/*
The format is MINUTE HOUR DAY_OF_MONTH MONTH DAY_OF_WEEK COMMAND
Use a comma to separate multiple values and a hyphen to indicate ranges.
If you need more than this, pick up a UNIX command reference. I did not
find the man files overly useful for crontab.
Berend Veldkamp wrote:
> Hi all,
> What is the best way to get rid of the temporary gif's that mapserver
> creates? Is it something my webserver takes care of, or do I have write
> a script to do this.
> TIA,
> Berend
> ______________________________________________
> ARIS - Hooghiemstraplein 126 - NL 3514 AZ Utrecht
> tel. +31 30 2769180 - fax. +31 30 2733578
> URL: http://www.aris.nl
