[mapserver-users] Expressions & SDE Layer
Robert Aldridge
bamarob55 at yahoo.com
Thu Jun 14 11:13:24 EDT 2001
Hello all,
I have a layer in my map file defined as follows:
LAYER
NAME "Roads"
TYPE LINE
STATUS DEFAULT
CONNECTIONTYPE sde
CONNECTION "comtrac,esri_sde,ArcInfo,sde,passwd"
DATA "sde.roads,shape"
CLASSITEM "roadtype"
CLASS
EXPRESSION /1/
SYMBOL 1
SIZE 1
COLOR 255 0 0
END
CLASS
EXPRESSION /2/
SYMBOL 1
SIZE 1
COLOR 0 0 0
END
END
Drawing the layer works fine without the expressions.
The "roadtype" item is defined as a SMALLINT in my
database. I get the following error with the above
layer definition:
sdeGetRecord(): SDE error. SE_stream_get_integer():
Wrong column type. (-114)
Changing the CLASSITEM to "cfcc" (which is a string
item) and using "A41" and "A31" in the two expressions
works fine.
I'm wondering if this might be a bug because it is
errorring out on SE_stream_get_integer when the item
type is smallint.
Any ideas?
Thanks,
Robert Aldridge
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year! http://personal.mail.yahoo.com/
