[mapserver-users] Compiling MapScript
Daniel Morissette
morissette at dmsolutions.ca
Mon Jun 25 16:50:14 EDT 2001
Stephen Lime wrote:
> That said it should be doable, pretty easily too given the main MapScript
> interface and the PHP implementation as guides. I would encourage any
> such development stay in sync with the main interface so that we could
> largely use the same set of docs.
For the record, I have some sample code that I wrote a few years ago and
that I could provide if someone needs an example of how to implement COM
bindings on top of a C/C++ library the hard way, that is doing
everything yourself and not using any IDE, wizard or other tool of this
kind. There may be better/easier tools to do this I guess... but I'm
passing the info just in case it could be of some help.
The code I'm talking about was implementing a COM interface on top of a
C++ lib that I was using to manipulate HTML templates, and it also
includes samples of accessing VB objects from the C++ code.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
