[mapserver-users] MapScript Java
Steve Lime
steve.lime at dnr.state.mn.us
Sun Mar 3 14:40:23 EST 2002
I've cleaned up the MapServer header files and the Swig interface file so that you can get a clean Java build without hacking the Swig output. I've included a java directory and a basic Makefile in the CVS which should be in tonites nightly. At the moment you'll need Swig (1.3.11 or higher) since the version installed on the UMN machines doesn't support Java very well. To build the java stuff...
1) cd mapscript/java
2) edit the Makefile to match your site (set location of java on your box and cc/ld flags)
3) type 'make'
You're on your own for installation/use at the moment. More later on those topics.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
