[mapserver-users] Fwd: imgxy
Vu Pham
vu at sivell.com
Wed Mar 27 07:30:13 EST 2002
If your current html template has had the form with appropriate
parameters, then I think you don't need to have another html file.
You can see the example of the demo or the tutorial.
Vu
-----Original Message-----
Sent: Wednesday, March 27, 2002 1:37 AM
To: Vu Pham; map_server4
Subject: Re: [mapserver-users] Fwd: imgxy
Vu Pham wrote:
> Steve Lime wrote:
>> Subject:
>> imgxy
>> From:
>> orkun <temiz at deprem.gov.tr>
>> Date:
>> Fri, 22 Mar 2002 16:58:59 +0200
>> To:
>> steve.lime at dnr.state.mn.us
>> Hi
>> I couldn't locate the maps at the center of the view when I performed
>> zooming, although
>> I manipulated imgxy. (But I don't know the logic of imgxy in depth. )
>> How can I solve this problem ?
>> Would you give some hints ?
>> Thanks in advance
> Let me try to answer your question [ I just got it answered yesterday
> When you don't click on the map itself , e.g. you click on the
> submit-type button of the form, then imgxy will be used as the center
> point for zooming.
> If the map size if X and Y, and imgxy will be "X/2-1 Y/2-1 " (
> perhaps X/2 -0.5 and Y/2 -0.5 is more exactly ).
> For example, my img size is 220 300 ( well, it loads it on my pocket
> pc ), then my form has this line :
> <input type="hidden" name="imgxy" value="109 149">
> ( When you click on the map then img.x and img.y will be used )
> HTH,
> Vu
Hi
Thank you very much.
You say "When you click on the map then img.x and img.y will be used".
In this case
I want to know if I have to build new html page for zooming or how to
change
existing page
kind regards
Ahmet Temiz
Geological Engineer
General Directorate
of Disaster Affairs
TURKEY
______________________________________
Scanned and protected by Inflex
http://pldaniels.com/inflex
