[mapserver-users] How to get rid of stock credits
Thomas P. Colson
tpcolson at nexussoft.com
Mon Nov 11 13:05:24 EST 2002
By editing line 386 of "build_phtml.php" in the htdocs directory, one can change the default credits to NOT change everytime GMAP factory is opened.
-----Original Message-----
From: Dean Gadoury [mailto:gadoury at dmsolutions.ca]
Sent: Tuesday, November 05, 2002 1:51 PM
To: Thomas P. Colson
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] How to get rid of stock credits
MapLab specific questions can be posted the the maplab list. To
subscribe see: http://lists.dmsolutions.ca/mailman/listinfo/maplab-users
To answer your question though: You can get rid of that text by editing
the html code for the page. The trick is that it is found in
x_contents.php, where x is the name you gave your application. You can
also modify other page elements in this file, like colours, fonts or
even the layout, but I will include 2 major cautionary notes.
1. If you modify any code in this file and re-open the project in
GMapFactory, your changes will be overwritten automatically by GMF. So
if you delete the credit line using your favorite text editor, then open
the project in GMF again the credit line will re-appear. This is the
expected and desired behaviour of GMF. So go ahead and make changes, but
it is best to make sure your application is finalized first. As long as
you don't open the project in GMF again you should have no problems.
2. Unless you really know what you're doing you shouldn't edit anything
inside the php code tags: <?php ?>
I hope that answers your question.
Dean
Thomas P. Colson wrote:
>How to get rid of "this application was built using GMapFactory" credit at bottom of page?
___________________________
Dean Gadoury
DM Solutions Group
72 Chamberlain Ave. Third Floor
Ottawa, Ontario. K1S 1V9
613 565-5056 ext. 24
www.dmsolutions.ca
