[Mapserver-users] PHP-4.3.x/Apache2/RH8 and mapscript issue
woodbri at swoodbridge.com
Fri Feb 21 19:30:29 EST 2003
Daniel,
Thanks, but I don't have --enable-debug in my configure script:
make clean
rm -f config.cache
./configure \
--without-tiff \
--without-eppl \
--without-jpeg \
--with-threads \
--with-proj \
--with-gdal=/usr/local/bin \
--with-ogr \
--with-php=../php-4.3.1 \
--with-gd=/usr/local \
--with-freetype=/usr/bin \
--with-pdf \
--with-ming \
--with-wmsclient \
--with-wfs \
--with-wfs-client
Did the default get change in ./configure
-Steve W.
On 21 Feb 2003 at 13:44, Daniel Morissette wrote:
> woodbri at swoodbridge.com wrote:
> > Hi all,
> > I was going to test the problem I reported yesterday ( about
> > PHP-4.3.x PHP/Mapscript processes not terminating and using up all
> > your cpu cycles ) on PHP-4.2.3 and Apache 2 but it seems that these
> > are not compatible, ie: you can't build a working PHP-4.2.3 CGI that
> > will work with Apache 2.
> > So does anyone else have PHP/Mapscript working with PHP-4.3.x and
> > Apache 2 on Red Hat 8.0 ( or any other OSs)?
> Steve,
> We do run PHP 4.2.3 under Apache 2 on RedHat 8, and we noticed this
> issue with processes never terminating at the time (I had forgotten
> about it until you wrote this). We found that it seems related to
> writing to stderr, so if you remove the --enable-debug in your
> MapScript build you should be fine. We never took the time to
> investigate any further to find the correct way to log messages to
> stderr under Apache 2.
> BTW, I think you wrote a Wiki page about setting up
> MapServer/MapScript on RH8, perhaps it would be a good idea to add a
> note about this issue in it.
> Daniel
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
