[Mapserver-users] Changing inline features with CGI parameters
Wim Blanken PI
wim.blanken at planet.nl
Mon Feb 2 09:12:03 EST 2004
Hello Jan,
Possible solutions......
-Did you specify the TYPE of the Layer?
-I use TRANSFORM OFF (and not False).
So......
TYPE annotation
TRANSFORM OFF
If this is no solution, could you specify a more complete mapfile?
Regards,
Wim Blanken
Geon bv
The Netherlands
----- Original Message -----
To: "'mapserver list'" <mapserver-users at lists.gis.umn.edu>
Sent: Monday, February 02, 2004 2:57 PM
Subject: [Mapserver-users] Changing inline features with CGI parameters
> Hi Steve and list,
> I'm trying to use a feature object for error messages. My mapfile looks
> like this:
> map
> layer
> end
> layer
> end
> layer
> transform false
> feature
> text "No data for this map
> points 10 10 end
> end
> class
> color 255 0 0
> end
> end
> Layers ar selected with expressions from the URL, and if no data are
> found, every layer but the last is turned off and the error message is
> displayed. Works fine. However, I want to be able to change the
> feature's text and position from the URL. The CGI Reference shows how to
> do this by creating a new feature from the URL:
...&map_webuser_feature=new&map_webuser_feature_points=12345.6789+12345.6789
&map_webuser_feature_text=My+House!&..
> This only works when *no* feature is defined in the MapFile, else
> nothing is shown. When omitting "feature=new" MapServer segfaults.
> AFAICS existing features are not accessible from the URL. Is this by
> design, or can something be done about it? I am thinking of an
> application with lots of default error messages that can be toggled on
> and off individually in different positions. It would be easier to do
> this with predefined (and named) feature objects. I can live with the
> present situation though.
> Jan
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
