[Mapserver-users] Australian Setup for MapServer
Gerry Creager N5JXS
gerry.creager at tamu.edu
Mon Feb 9 09:32:04 EST 2004
You might want to start with an abbreviated map file for the shp's, or
even for a single .shp file, and see if you can get that to work. It's
also acceptable to send a file snippet to the list when asking for help.
Confirm the projection you're working in with the .shp files, and look
again at your extents. Make sure the units are consistent. I am not
familiar with AGD projection... but according to the proj EPSG file, it
appears to have either a UTM version (EXTENT would them be in meters)
and a lat/lon version: that'd be in decimal degrees, with South and West
represented as negative values.
Hopefully this will get you pointed on the right track. Remember to
post to the list for responses, as A) someone who's been bitten like
this might be able to help now, and B) it might help someone in the
future. Archives are your friend!
The snippet below should get you some direct idea of how a working
version is set up. It's a portion of my .map for
http://mesonet.tamu.edu/currentwx.html:
NAME TxMeso
STATUS ON
SIZE 700 700
#SIZE 650 650
EXTENT -106.8 25.8 -93.52 36.4
UNITS DD
SHAPEPATH "/var/www/mesonet/texas/data"
IMAGECOLOR 255 255 255
FONTSET "fonts.list"
SYMBOLSET "symbols.sym"
IMAGETYPE PNG
WEB
TEMPLATE "mesonet1.html"
FOOTER mesonet_footer.html
MINSCALE 25000
MAXSCALE 50000000
IMAGEPATH "/var/www/mesonet/tmp"
IMAGEURL "/tmp/"
METADATA
WMS_TITLE "MesoNet Texas"
WMS_ABSTRACT "Realtime Weather Interface"
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://mesonet.tamu.edu/index.php"
WMS_SRS "EPSG:4269"
END
END
Start of scalebar
SCALEBAR
BACKGROUNDCOLOR 0 0 0
LABEL
COLOR 128 128 255
# COLOR 1 1 1
SIZE medium
END
STYLE 1
SIZE 150 4
COLOR 128 128 255
# UNITS MILES
UNITS kilometers
INTERVALS 4
TRANSPARENT TRUE
STATUS on
END
# Legend
LEGEND
STATUS ON
POSTLABELCACHE ON
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 5 5 END
FILLED FALSE
END
SYMBOL
NAME 'pwvcircle'
TYPE ELLIPSE
FILLED TRUE
POINTS 10 10 END
END
LAYER
SIZEUNITS pixels
NAME rain
TYPE line
DATA rain_dd
STATUS false
CLASS
NAME 'Rainfall Contours'
COLOR 25 20 200
END # CLASS
END # LAYER
# Roads
LAYER
SIZEUNITS pixels
PROJECTION
"init=epsg:4269"
END
NAME roads
TYPE line
DATA usdotrds
STATUS false
CLASS
NAME 'Roads'
COLOR 132 132 132
END
END # LAYER
# Lakes and Rivers
LAYER
SIZEUNITS pixels
PROJECTION
"init=epsg:4269"
END
NAME rivers
TYPE polygon
DATA hydgen
STATUS false
CLASS
NAME 'Lakes & Rivers'
TEMPLATE "lakes.html"
COLOR 100 125 225
END
HEADER "lakes_header.html"
FOOTER "lakes_footer.html"
TOLERANCE 3
END # LAYER
# Radar Layer
LAYER
TYPE RASTER
STATUS ON
NAME radar
SIZEUNITS pixels
PROJECTION
"init=epsg:4269"
END
DATA "/var/www/mesonet/gemdata/images/radar/01_mesonet.gif"
OFFSITE 255 255 255
CLASS
COLOR -1 -1 -1
NAME 'Doppler Radar Mosaic'
END
END # LAYER
Nick Dabner wrote:
> Thanks for the advice Yuri. Have ordered the Ausway (Melways, Sydways)
> street directories, but have the Sensis maps available. They are in ESRI
> shapefile format, but fail to load. I hope running on OS X isnt the issue.
> Actually think it is a projection (AGD?) and extent issue. I am
> attempting to map melbourne, but the map extent always comes up as 1
> mile or smaller.
> Will keep fiddling.Think a re-read of the users manual may be in order.
> Nick
> On 09/02/2004, at 10:53 AM, Balkanu GIS wrote:
>> Hi Nick,
>> Am a newbie to Mapserver too but have successfully shown ESRI
>> shapefiles for
>> Cape York (Queensland) by specifying the map extent as
>> EXTENT 140 -11 147 -15
>> Not familiar with Sensis or Ausways shapefiles - if they are the same
>> format
>> as ESRI .shp they should display. Otherwise, MapServer would need to have
>> support for the file type compiled into it. And I don't suppse the
>> standard
>> version would, since they would not be common or standard types.
>> Good luck, keep us informaed
>> Yuri
>> -----Original Message-----
>> From: mapserver-users-admin at lists.gis.umn.edu
>> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
>> dabner at optusnet.com.au
>> Sent: Sunday, 8 February 2004 16:45
>> To: mapserver-users at lists.gis.umn.edu
>> Subject: [Mapserver-users] Australian Setup for MapServer
>> hello,
>> New to mapserver and have been pluggin
>> away with little success to get it to show my
>> part of the world. Does anyone have some
>> experience using sensis or ausways maps in
>> mapserver. Just need a start as mapserver is
>> rejecting the shapefiles.
>> regards,
>> Nick Dabner
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
