Virtual Spatial Data through OCI
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Thu Jul 21 07:46:48 EDT 2005
Hi list,
probably a question for Frank.
I am trying to use an Oracle X Y column table through virtual spatial data. I compiled GDAL against the Oracle client. I can access it through ODBC without any problems.
When doing an ogrinfo on the ovf file I created, I get:
D:\ms4w\apps\stragisweb\htdocs\sites\westland\data>ogrinfo adr4all.ovf
ERROR 4: Update access not supported for VRT datasources.
ERROR 1: Failed to find layer 'ADR5_ADRESCYCLUS' on datasource 'OCI:CAB/CAB at 10.1
5.7.7:1521/ONTW'.
FAILURE:
Unable to open datasource `adr4all.ovf' with the following drivers.
-> ESRI Shapefile
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> MapInfo File
-> DGN
-> VRT
-> AVCBin
-> REC
-> Memory
-> CSV
-> GML
-> ODBC
-> OCI
My ovf file looks like:
<OGRVRTDataSource>
<OGRVRTLayer name="adr4all">
<SrcDataSource>OCI:CAB/CAB at 10.15.7.7:1521/ONTW</SrcDataSource>
<SrcLayer>ADR5_ADRESCYCLUS</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>epsg:28992</LayerSRS>
<GeometryField encoding="PointFromColumns" x="X_KOORD" y="Y_KOORD"/>
</OGRVRTLayer>
</OGRVRTDataSource>
When I do a direct ogrinfo sql select command it works fine:
D:\ms4w\apps\stragisweb\htdocs\sites\westland\data>ogrinfo -ro OCI:CAB/CAB at 10.15
..7.7:1521/ONTW -sql "SELECT * FROM ADR5_ADRESCYCLUS WHERE ADRESNR=41812"
INFO: Open of `OCI:CAB/CAB at 10.15.7.7:1521/ONTW'
using driver `OCI' successful.
Layer name: SELECT * FROM ADR5_ADRESCYCLUS WHERE ADRESNR=41812
Geometry: Unknown (any)
Feature Count: 1
Layer SRS WKT:
(unknown)
ADRESNR: Integer (10.0)
VOLGNR: Integer (3.0)
LANDKODE: String (4.0)
GEMEENTEKODE: String (4.0)
WOONPLKODE: String (4.0)
WOONPL_BOCO: String (24.0)
WOONPL_BOCO_U: String (24.0)
WOONPL_BOCO_D: String (30.0)
STRAATKODE: String (5.0)
STRAAT: String (40.0)
STRAAT_U: String (40.0)
STRAAT_D: String (50.0)
AAND: String (2.0)
HUISNR: Integer (5.0)
HUISLT: String (1.0)
TOEV: String (4.0)
POSTK_A: String (2.0)
POSTK_N: Integer (4.0)
WIJKKODE: String (3.0)
BUURTKODE: String (6.0)
SRT_ADRESKODE: String (3.0)
STATUSKODE: String (3.0)
X_KOORD: Real (9.3)
Y_KOORD: Real (9.3)
Z_KOORD: Real (9.3)
LOKATIE: String (40.0)
LOKATIE_D: String (50.0)
VRIJ_VELD1: String (10.0)
VRIJ_VELD2: String (10.0)
OGRFeature(SELECT * FROM ADR5_ADRESCYCLUS WHERE ADRESNR=41812):0
ADRESNR (Integer) = 41812
VOLGNR (Integer) = 1
LANDKODE (String) = 6030
GEMEENTEKODE (String) = 1783
WOONPLKODE (String) = 10
WOONPL_BOCO (String) = De Lier
WOONPL_BOCO_U (String) = DE LIER
WOONPL_BOCO_D (String) = De Lier
STRAATKODE (String) = 13040
STRAAT (String) = Witte de Withstraat
STRAAT_U (String) = WITTE DE WITHSTRAAT
STRAAT_D (String) = Witte de Withstraat
AAND (String) = (null)
HUISNR (Integer) = 15
HUISLT (String) =
TOEV (String) =
POSTK_A (String) = GE
POSTK_N (Integer) = 2678
WIJKKODE (String) = (null)
BUURTKODE (String) = (null)
SRT_ADRESKODE (String) = (null)
STATUSKODE (String) = (null)
X_KOORD (Real) = 77334.060
Y_KOORD (Real) = 443550.020
Z_KOORD (Real) = (null)
LOKATIE (String) = (null)
LOKATIE_D (String) = (null)
VRIJ_VELD1 (String) = N
VRIJ_VELD2 (String) = 5,27163
I am confused. Any ideas?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
