mapserver tif projections
Frank Warmerdam
fwarmerdam at GMAIL.COM
Thu Jul 28 14:54:48 EDT 2005
On 7/28/05, Douglass Davis <douglass_davis at earthlink.net> wrote:
> Hello All,
> I just got an elevation tif file (w/aux,prj, and tfw) from the seamless
> data distribution center: http://seamless.usgs.gov/. I am still trying to
> understand projections, I read through the tutorial and user manual and
> looked through the proj4 documentation, but I am still not really sure how
> to do this.
> Now, I know it uses Lambert Azimuthal Equal Area Projection. But, how do I
> represent this projection in a map file, and pass the needed parameters into
> proj4?
> I tried putting this in my Raster tif layer:
> PROJECTION
> "proj=laea"
> "lon_0=100.00w"
> "lat_0=45.00n"
> END
> But it didn't work. Can some one help me with getting the correct
> parameters to put in the map file?
> Ellipsoid_Name: Sphere Semi-major_Axis: 6370997.0
> Denominator_of_Flattening_Ratio: 1.0
Douglass,
In what way did it not work?
Try adding "ellps=sphere" to your definition. Your current definition has
no earthmodel definition and depending on your setup there may be no
default.
Note that most projections on a sphere don't map well to conventional
ellpisoid coordinate systems. You may find you need to use "ellps=WGS84"
instead to get good correspondence.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
