mapserver tif projections
Douglass Davis douglass_davis at EARTHLINK.NET
Thu Jul 28 12:49:40 PDT 2005
Frank Warmerdam wrote:
>Douglass,
>In what way did it not work?
>Try adding "ellps=sphere" to your definition.  Your current definition has
>no earthmodel definition and depending on your setup there may be no
>default.
>Note that most projections on a sphere don't map well to conventional
>ellpisoid coordinate systems.  You may find you need to use "ellps=WGS84"
>instead to get good correspondence.
>Good luck,
Thanks.
Now I have:
 LAYER
   NAME         elevation
   DATA         "elevation/05539624.tif"
   TYPE         RASTER
   STATUS       ON
   PROJECTION
     "proj=laea"
     "lon_0=100w"
     "lat_0=45n"
     "ellps=sphere"
   END
 END
Before, it gave an error when trying to do the projection.
Warning: [MapServer Error]: msProcessProjection(): major axis or radius
= 0 or not given in c:\program files\apache
group\apache\htdocs\mapserver\nc.php on line 4
Now I get a map and that error went away (progress :-) .  But, still, no
tif layer.
my (lat/lon) extent for the whole thing is:
  EXTENT -85 32 -75 38
Should the extent be in meters?  Isn't putting the projection in the
layer supposed to make that transformation?  All of my other layers just
use lat/lon not LAEA and they work fine.  So, I'm mixing two types of
coordinates here, and it's still a mystery to me as far as how this is
supposed to work.
Spatial_Domain:
    Bounding_Coordinates:
        West_Bounding_Coordinate:-84.84957627
        East_Bounding_Coordinate:-74.99646893
        North_Bounding_Coordinate:37.47563559
        South_Bounding_Coordinate:33.16490113
    Spatial_Reference_Information:
        Horizontal_Coordinate_System_Definition:
            Planar:
                Map_Projection:
                    Map_Projection_Name: Lambert Azimuthal Equal Area
                    Lambert_Azimuthal_Equal_Area:
                        Longitude_of_Projection_Center: -100.00
                        Latitude_of_Projection_Center: 45.00
                        False_Easting: 0.0
                        False_Northing: 0.0
                Planar_Coordinate_Information:
                    Planar_Coordinate_Encoding_Method: Row and column
                    Coordinate_Representation:
                        Abscissa_Resolution: 1000.0
                        Ordinate_Resolution: 1000.0
                    Planar_Distance_Units: Meters
            Geodetic_Model:
                Horizontal_Datum_Name: None
                Ellipsoid_Name: Sphere
                Semi-major_Axis: 6370997.0
                Denominator_of_Flattening_Ratio: 1.0
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050728/4d595765/attachment.htm>
More information about the MapServer-users mailing list
