Mapserver and SDE, one trivial question,
one informational question
Farber, Saul (ENV)
Saul.Farber at STATE.MA.US
Mon Mar 14 15:39:37 EST 2005
Hello Mapserver Gurus,
First off, thanks much for such a wonderful project. You guys are truly
making some incredible software and it's exciting to know that this
level of experience is helping so many people.
Two questions.
1) I have the following .map file:
MAP
DEBUG ON
CONFIG PROJ_LIB ../mapserver-bundle-4.4.1/proj-4.4.9/share/proj
NAME test
STATUS on
UNITS meters
EXTENT 221593.91942230912 882446.3536074255 253829.55453864884
914171.7844269598
SIZE 800 600
WEB
IMAGEPATH "/tmp/"
IMAGEURL "/tmp/"
LOG "/tmp/mapserver.log"
END
LAYER
CONNECTIONTYPE sde
CONNECTION "localhost,port:5151,xxx,xxx,xxx"
DATA "MYLAYER_ARC,shape"
DEBUG ON
NAME roads
FILTER "where ADMIN_TYPE is not NULL"
STATUS on
TYPE line
CLASS
DEBUG ON
NAME "Roads"
COLOR 10 10 10
SYMBOL 1
END
END
END
The point of this layer is to classify roads with an admin_type of 1
(hence the filter) into many different thematic classes. Some in red,
some in blue, some in black, etc.
I have tried many different EXPRESSION lines in the CLASS section. Here
are some examples:
EXPRESSION "[ADMIN_TYPE] = 1"
EXPRESSION "'[ADMIN_TYPE]' = 1"
EXPRESSION "'[ADMIN_TYPE]' = '1'"
EXPRESSION "'[ADMIN_TYPE]' eq 1"
EXPRESSION "'[ADMIN_TYPE]' eq '1'"
EXPRESSION "'[ADMIN_TYPE]' IN '1'"
EXPRESSION "'[ADMIN_TYPE]' LIKE '%1%'"
Etc.
I've tried all the combinations of attribute name and quotes/operators I
can think of. I've tried the attribute name fully qualified, partially
qualified and unqualified (as above).
In all cases, I get a completely blank map, as though no features are
selected by the expression. Any hints on what I should be putting in
for the expression? Are Expressions supported in SDE layers?
2) Completely unrelated to the first question: how does mapserver
handle Database connections (SDE in particular) with regards to
scalability?
Are new DB connections created every time that a map request is sent?
Are database connections pooled in any way? Are the different layers in
a map request rendered sequentially, or in parallel?
Thanks once again for a great project.
--saul
GIS Web Services
MassGIS - Executive Office of Environmental Affairs
251 Causeway Street
5th Floor
Boston, MA 02114
617-626-1145
