coordinate systems transformations
Gregor Mosheh
stigmata_blackangel at YAHOO.COM
Thu Mar 24 19:39:31 EST 2005
> Does map server provides methods for transformation
> among the various coordinate systems that are used
> in the application (i.e. degrees,
> georeference extents, pixels, etc)?
MapServer itself does not. But there are ways to do it
that aren't terribly complicated. The following recipe
is how I made a map image clickable, while keeping
track of the projected coords.
// handle_map_click() figures out the map coords of
where you clicked
// and sets the variables coord_x and coord_y
// the [minx], et al are MapServer template markups
and will be replaced with
// the correct numbers automagicallly
// the image size is hardcoded, but there is probably
a MapServer markup
// that would have filled those in, too
// The variable 'image' is the HTML/DOM image object,
so be sure to name your image
function handle_map_click(image) {
// some things are hardcoded
image_width = 200;
image_height = 200;
// the current display map's boundaries
var display_lower_x = [minx];
var display_lower_y = [miny];
var display_upper_x = [maxx];
var display_upper_y = [maxy];
// convert the mouse click into pixelcoords
clickcoords = GetClickCoordinates();
imagecoords = GetObjectCoordinates(image);
click_x = clickcoords.x - imagecoords.x;
click_y = clickcoords.y - imagecoords.y;
click_y = image_height - click_y; // for GIS, the
origin is lower-left, not upper-left
// figure out how many meters are represented by 1
pixel
var x_perpixel = (display_upper_x -
display_lower_x) / image_width ;
var y_perpixel = (display_upper_y -
display_lower_y) / image_height;
// now convert pixels into meters
coord_x = display_lower_x + (click_x * x_perpixel)
coord_y = display_lower_y + (click_y * y_perpixel)
// we don't want to actually return anything, cuz
we're probably being called
// by a click on an image, and returning false
keeps the form from being submitted
return false;
These other two functions I got from the 'net
someplace. Sadly, I don't recall where so I am unable
to give credit. They figure out mouse clicks and image
positions.
// a function to fetch the location of the mouse-click
relative to the document's origin
function GetClickCoordinates() {
if (window.Event) {
mouseX = e.pageX;
mouseY = e.pageY;
else {
mouseX = window.event.clientX +
document.body.scrollLeft;
mouseY = window.event.clientY +
document.body.scrollTop;
return {x:mouseX, y:mouseY}
// a function to return the location of an object
function GetObjectCoordinates(obj) {
return { x:GetObjectX(obj) - 2, y:GetObjectY(obj) -
2 };
function GetObjectX(obj) {
var curleft = 0;
if (obj.offsetParent) {
while (obj.offsetParent) {
curleft += obj.offsetLeft
obj = obj.offsetParent;
else if (obj.x) {
curleft += obj.x;
return curleft-2;
function GetObjectY(obj) {
var curtop = 0;
curtop += obj.offsetTop
else if (obj.y) {
curtop += obj.y;
return curtop-2;
To make the image active and clickable, I use a form
whose input "button" is the image:
<form>
<input type="image" src="[img]" onClick="return
handle_map_click(this);">
</form>
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
