ogr connecting to .tab files
Frank Warmerdam
warmerdam at POBOX.COM
Thu Jun 8 23:10:13 EDT 2006
Donal Regan wrote:
> Hi Frank,
> Thanks for the reply.
> What I have is a load of .tab files with corresponding .TIF files. The
> .tab files have Type : "RASTER" in the definition table so I presume
> that means they're not supoorted. Does this mean I can't use them as a
> Mapserver datasource at all? Or can I convert them somehow into a format
> supported by Mapserver?
Donal,
There have been other discussions of roughly this topic either here or on
gdal-dev recently. You might want to take a look. Generally speaking
you can write a script that will translate the .tab files into .wld files
or use them to attach gcps to the .tif files using gdal_translate.
You may also find you can convert them into proper GeoTIFFs with MapInfo.
But currently gdal won't do it all for you.
Sorry,
and watch the world go round - Rush | President OSGF, http://osgeo.org
