compile MapServer to support Oracle Spa tial
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Tue Jun 13 07:29:21 EDT 2006
You need to install the Oracle client libraries (which include OCI), not
Oracle server.
The easiest you can use is the Oracle instant client which is less than 100
Mb and can just be deployed by unpacking a ZIP. You also need the Instant
Client SDK then for the header files. Check the Oracle site.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens
Zhonghai Wang
Verzonden: dinsdag 13 juni 2006 11:46
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] compile MapServer to support Oracle Spatial
Hi there,
I am now trying to compile MapServer to support Oracle Spatial, I find the
info in the nmake.opt:
# Direct connectivity to Oracle Spatial.
# Point this to where your ORACLE_HOME directory lives.
ORACLE_DIR = d:\oracle\ora92
ORACLE=-DUSE_ORACLESPATIAL
does this mean that I must install Oracle on my computer, before I compile
the MapServer? If not necessary, how can I set the
ORACLE_DIR = value? set it as a virtual directory?
thanks
zhonghai
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060613/2407abd5/attachment.html
