MapServer incompatibility with RHEL4/CE NTOS4.2
Steven Bowden
steveb at BUNDABERG.QLD.GOV.AU
Sun Mar 5 17:56:59 EST 2006
No Problems with mapserver-4.6.2 on CentOs 4.2 here on a Dual Code AMD 64
running 32bit;
I am using
proj-4.4.9
gd-2.0.33
gdal-1.3.1
geos-2.2.1
mapserver-4.6.2
php-4.4.0
gcc 3.4.4
glibc-2.3.4-2.13
freetype-2.1.9-1
Mapserver config
./configure --with-postgis --without-tiff --with-jpeg --with-threads
--with-proj=/usr/local --with-gdal=/usr/local/bin/gdal-config
--with-php=../php-4.4.0 --with-gd=/usr/local --with-freetype=/usr/bin
--with-ogr=/usr/local/bin/gdal-config --with-wms --with-wfs --with-wcs
--with-geos=/usr/local/bin/geos-config --enable-debug
Regards
Steve
On Sat, 4 Mar 2006 2:58 am, Doyon, Jean-Francois wrote:
> I tried moving the RedHat 7.3 binary that I know works fine to a CentOS 4.2
> system, and wham, the problem appeared!
> I also investigated trying to run multiple glibc's to see if that might be
> the problem (i.e. install the RedHat 7.3 glibc on CentOS for the use of
> MapServer), but that looks like quite the nightmare to try out ...
> J.F.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Doyon, Jean-Francois
> Sent: March 3, 2006 10:28 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] MapServer incompatibility with RHEL4/CE
> NTOS4.2
> OK, we're running 32 bit CentOS 4.2, on Xeon processors.
> I'm thinking there's some problem with the newer glibc or something like
> that, which would also explain the crashes I was having at first on a
> specific map?
> J.F.
> Sent: March 3, 2006 9:56 AM
> NTOS4.2
> Lowell,
> Indeed! These are 64 bit CPU's! (Intel Xeon, Dell PowerEdge 1850's)
> And we're running CentOS, though I'm not sure whether it's the i386
> version, or the x86_64 one, I'll look into that.
> I've also replicated the problem on a Pentium 4 machine though, which is 32
> bit, though with what intel calls EM64T technology.
> Could it be the HyperThreading?
> J.F.
> From: Lowell.Filak [mailto:lfilak at medinaco.org]
> Sent: March 3, 2006 9:41 AM
> To: Doyon, Jean-Francois
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> RHEL4/CENTOS4.2
> Doyon, Jean-Francois writes:
> > Hello,
> > OK well I've tracked down the source of my problem to the operating
> > system itself it seems.
> > Regardless of the versions/combinations of mapserver/gd/freetype I
> > use, there are definite visual rendering problems when on this OS. On
> > RedHat 7.3, everything is fine!
> > Example:
> > http://atlas.gc.ca/family-good.gif
> > http://atlas.gc.ca/family-bad.gif
> > Note the small dot that appears on the symbol?
> > Also:
> > http://atlas.gc.ca/the-market-good.gif
> > http://atlas.gc.ca/the-market-bad.gif
> > Notice how on the bad version, a bunch of point symbols are missing?
> > I tried various combinations of:
> > MapServer 4.6.1 and 4.8.1
> > FreeType 2.0.9 and 2.1.9
> > GD 2.0.28 and 2.0.33
> > A given combination works on 7.3, but not on CentOS.
> > Without luck. The problem with the strange shape of the symbols (
> > http://atlas.gc.ca/mapserver-symbol-problem.png ) seemes to be related
> > to the version of FreeType for some reason? FreeType 2.0.9 acts as we
> > expect it to, FreeType 2.1.9 does not. There may be cumulative
> > effects
> also.
> > CentOS 4.2 uses GCC 3.4.4 and GLIBC 2.3.4. I had gotten a horrible
> > crash message at some point with a version of mapserver on this OS
> > (http://lists.umn.edu/cgi-bin/wa?A2=ind0602&L=mapserver-users&P=R60802
> > &I=-3& X=106ECE1CAE6B73E23F), but upgrading from 4.6.1 to 4.8.1 had
> > fixed it. This was related to memory allocation. Could something
> > related to that be causing this? Turns out I've got 4.6.1 running on
> > this platform now, but that really didn't help.
> > I'm out of ideas :( Anyone?
> J.F.,
> Is the 7.3 box a 32-bit and the RHEL box a 64-bit kernel by any chance (you
> may have already stated that in your previous "double free detected.." post
> but I don't remember). Not that I know of a particular fix, but we have
> certainly had strange problems here also.
> Lowell
