php mapscript error
Kipp Jones
kippster at YAHOO.COM
Fri Nov 3 22:20:04 EST 2006
You gents are great...I really appreciate the help, and I can see how
focus on the binary would be most helpful for all involved! Sorry I
went old school and tested out the aged instructions, a shame since
they are so good.
I thought maybe I was going nuts (which is still not out of the
question). But the issue seems to be that my gdal-config is located
in /usr/local/bin/ but the configure script was looking for it in /sw/
bin/. When I initially tried the --ogr-enabled without the path, it
yelled at me...your comments led me to the answer.
I added a symbolic link in /sw/bin/, re-ran the configure without the
path info (for either the gdal or the ogr option), make clean, make,
re-installed, and life is good.
The final configure command I used:
./configure --mandir=/usr/local/share/man --with-proj=/usr/local --
with-gdal --with-ogr --with-gd=/usr/local --with-xpm=/usr/X11R6 --
with-php=/usr/local --with-geos --with-wfs --with-wcs --with-
wfsclient --with-wmsclient --with-freetype=/usr/:qX11R6/bin/freetype-
config
And what php now tells me:
MapServer Version
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=GEOS INPUT=EPPL7
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Thanks for the quick responses, the great directions and all of your
help!
Kipp
On Nov 3, 2006, at 6:40 PM, William Kyngesburye wrote:
> On Nov 3, 2006, at 5:27 PM, Kipp Jones wrote:
>> Thanks William & Aaron...great to have such quick response.
>> I did end up building it on my own -- and boy was that fun :-) I
>> was following the information (thanks btw!) on http://
>> www.kyngchaos.com/macosx/install/mapserv -- but grabbed the
>> 4.10.0 version instead of the 4.6.0 version...
> Those directions are out-of-date, though they may still be usable -
> I'm focusing on the binaries nowadays.
>> Here is the configure comman I used:
>> with-gdal=/usr/local/bin/gdal-config --with-ogr=/usr/local/bin/
>> gdal-config --with-gd=/usr/local --with-xpm=/usr/X11R6 --with-php=/
>> usr/local --with-geos=/usr/local/bin/geos-config --with-wfs --with-
>> wcs --with-wfsclient --with-wmsclient --with-freetype=/usr/:qX11R6/
>> bin/freetype-config
>> I swear I tried to use a package install earlier on in the
>> process, but perhaps I should drop back and try that again...
> Well, since the ogrinfo command works, there's nothing wrong with
> OGR. But that build line for mapserver could be a problem - you
> don't need to specify the gdal-config path for the --with-ogr
> option, and in fact that may break the option. Try it as:
> --with-gdal=/usr/local/bin/gdal-config --with-ogr
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike. Cheating, murdering, lying,
> fighting, and all for things that the beasts of the jungle would
> not deign to possess - money to purchase the effeminate pleasures
> of weaklings. And yet withal bound down by silly customs that make
> them slaves to their unhappy lot while firm in the belief that they
> be the lords of creation enjoying the only real pleasures of
> existence....
> - the wisdom of Tarzan
