python mapscript with IIS
william paul
williampaul28 at YAHOO.COM
Sat Nov 4 10:44:14 EST 2006
Hi Rich:
IIS was configured to work with Python scripts. I did the configuration according to http://support.microsoft.com/kb/276494
I have removed #! c:\python24\python -u from the make_dlegend_xml.py and make_dlegend_xml_cgi.py. I tried as you told me to test the script, and I get the error:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
- <dLegend>
<error>Missing required parameter "server"</error>
</dLegend>
When I look at the javascript console I see:
Error: xml declaration not at start of external entity
Source File: http://localhost/scripts/make_dlegend_xml_cgi.py?map=c:/inetpub/wwwroot/demo/example/itasca.map&server=localhost
Line: 2, Column: 1
Source Code:
<?xml version="1.0" ?>^
What is strange is that the legend appears OK and I can work with it, but it is obvious that somewhere something is wrong and I can understand where!
Thank you again
William
Richard Greenwood <richard.greenwood at gmail.com> wrote: On 11/3/06, william paul wrote:
> Hi again to everybody:
> I am trying to use the example provided with dBox, and to combine mapscript
> python with dbox on IIS. I have installed dBox and seems to work, but I have
> problems with mapscript python. These are steps which I did so far:
> I have downloaded a installed on windows xp sp 2 with IIS, mapserver 4.10. I
> used the the binaries from MS4W, latest stable version from www.maptools.org
> I have downloaded and installed Python 2.4.3
> I have copied mapscript.py, mapscript.pyd and _mapscript.pyd into
> Python24/Lib/site-packages
> I have copied make_dlegend_xml.py. make_dlegend_xml_cgi.py,
> make_dlegend_xml.pyc into c:/inetput/scripts/
> I have modified the example.html to point the correct path
> In javascript console I get the error:
> Error: objDomTree.getElements("server")[0] has no properties
> Yet another dlegend initialization error. Implies that dlegend.js has
> received some data, but not in the expected form
> When I test the mapscript python installation I get the error:
> CGI Error
> The specified CGI application misbehaved by not returning a complete set of
> HTTP headers. The headers it did return are:
I don't think you have IIS configured to render any Python scripts.
IIS does not recognize the #!C:\Python24\python.exe convention.
Instead, you use IIS manager to map the .py extension to the Python
inturperter.
Open IIS manager, and properties for your web site, pick
"configuration" from the "Home Directory" tab. Under the "mappings"
tab, pick "Add":
Executable: C:\Python24\python.exe -u %s %s
Extension: .py
Verbs: All
Now try your test Python script.
If you are having troubles with make_dlegend_xml_cgi.py, call it
directly with something like:
http://localhost/make_dlegend_xml_cgi.py?map=/path/to/yourMapFile.map?server=localhost
This way you will see errors that make_dlegend_xml_cgi.py produces,
not the downstream errors that is has created in your JavaScript.
e.g. objDomTree.getElements("server")[0] has no properties
Rich
Richard Greenwood
www.greenwoodmap.com
Want to start your own business? Learn how on Yahoo! Small Business.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061104/4d1994db/attachment.html
