SVG-Legend
Miklos Geyer
miklos.geyer at ELKB.DE
Mon Nov 6 17:41:23 EST 2006
Am 06.11.2006 um 16:31 schrieb Yewondwossen Assefa:
> Miklos Geyer wrote:
>> Hi,
>> thanks for the info, although it's not the best message ;-)
>> Are there any plans to implement Lengends / Scalebars in SVG?
> There is no current plan to add these functions. The initial
> project was limited to do the map output only.
> If you are familiar with mapscript, It should be possible to
> generate an svg legend by looping through the map/layer/class objects.
yes, my applicatioin is based on php mapscript. Because I offer SVG-
Downloads, the best thing would be to emded the legend into the map.
Is ist possible to get and modify /add the svg-xml direct before it
is written in the tmp-Dir?
... maybe a stupid question?
>> Am 06.11.2006 um 15:31 schrieb Yewondwossen Assefa:
>>> Hi There,
>>> Only Map output is supported in SVG. Such things as Legend and
>>> Scalebar are not supported.
>>> Miklos Geyer wrote:
>>>> Hi,
>>>> I'm still struggling with Legends in SVG.
>>>> The same Mapfile with IMAGETYPE png shows the Legend (and
>>>> Scalebar).
>>>> Ist this not implemented in MapServer 4.8 ?
>>>> Any help / hints / examples appreciated.
>>>> Miklós
>>> Assefa Yewondwossen
>>> Software Analyst
>>> Email: assefa at dmsolutions.ca
>>> http://www.dmsolutions.ca/
>>> Phone: (613) 565-5056 (ext 14)
>>> Fax: (613) 565-0925
> Assefa Yewondwossen
> Software Analyst
> Fax: (613) 565-0925
