SVG-Legend
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Mon Nov 6 20:31:01 EST 2006
Miklos Geyer wrote:
> Am 06.11.2006 um 16:31 schrieb Yewondwossen Assefa:
>> Miklos Geyer wrote:
>>> Hi,
>>> thanks for the info, although it's not the best message ;-)
>>> Are there any plans to implement Lengends / Scalebars in SVG?
>> There is no current plan to add these functions. The initial
>> project was limited to do the map output only.
>> If you are familiar with mapscript, It should be possible to generate
>> an svg legend by looping through the map/layer/class objects.
> yes, my applicatioin is based on php mapscript. Because I offer SVG-
> Downloads, the best thing would be to emded the legend into the map.
> Is ist possible to get and modify /add the svg-xml direct before it is
> written in the tmp-Dir?
> ... maybe a stupid question?
If I understand correctly, you could possibly do a
$map->save("myfile.svg"), then load this svg with php and insert
features that you want and return the result to the user.
>>> Am 06.11.2006 um 15:31 schrieb Yewondwossen Assefa:
>>>> Hi There,
>>>> Only Map output is supported in SVG. Such things as Legend and
>>>> Scalebar are not supported.
>>>> Miklos Geyer wrote:
>>>>> Hi,
>>>>> I'm still struggling with Legends in SVG.
>>>>> The same Mapfile with IMAGETYPE png shows the Legend (and Scalebar).
>>>>> Ist this not implemented in MapServer 4.8 ?
>>>>> Any help / hints / examples appreciated.
>>>>> Miklós
>>>> Assefa Yewondwossen
>>>> Software Analyst
>>>> Email: assefa at dmsolutions.ca
>>>> http://www.dmsolutions.ca/
>>>> Phone: (613) 565-5056 (ext 14)
>>>> Fax: (613) 565-0925
>> Assefa Yewondwossen
>> Software Analyst
>> Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
