I need the ability to be able to display ECW and JPEG2000
format files within MapServer via a Community Mapbuilder client
which sends WMS requests for the images to MapServer
Frank Warmerdam
warmerdam at POBOX.COM
Thu Nov 30 15:07:10 EST 2006
John Mitchell wrote:
> Hi Frank,
> I now able to display ECW type files via mapserver within a community
> mapbuilder web browser client. I had question on part of the sample map
> file that you sent:
> OUTPUTFORMAT
> NAME jpeg2000
> DRIVER "GDAL/JP2ECW"
> MIMETYPE "image/jpeg2000"
> FORMATOPTION "TARGET=95"
> IMAGEMODE RGB
> END
> What does TARGET=95 mean?
John,
This means that I am requesting 95% reduction in image size during
compression - ie. 20:1 compression.
> I am having good success (as far as image quality and small size
> downloaded to the browser) with displaying my image data as jpeg within
> community mapbuilder as an example
> <FormatList>
> <Format current="1">image/jpeg</Format>
> </FormatList>
> But when I try displaying it as a png as an example. I get poor quality
> as far as the color.
> <FormatList>
> <Format current="1">image/png</Format>
> </FormatList>
You like want PNG24 format. The plain PNG format results in a reduction
to 8bit which causes a lot of damage to the image. The predefined 24bit
PNG output format is called "PNG24", and has a mimetype of
"image/png; mode=24bit"
> What application do you use to create your .ECW files?
The original ecw file I was serving from was one I downloaded from
geotorrent.org. But I do sometimes use gdal_translate to produce
ecw files.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
