I need the ability to be able to display ECW and JPEG2000
format files within MapServer via a Community Mapbuilder client
which sends WMS requests for the images to MapServer
John Mitchell
mitchelljj98 at GMAIL.COM
Thu Nov 30 15:34:43 EST 2006
Frank,
The ECW is already in a compressed format, so this means that the image is
compressed another 95%? This additional compression is for performance
purposes?; does it affect the image quality?
Thanks,
John
On 11/30/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> John Mitchell wrote:
> > Hi Frank,
> > I now able to display ECW type files via mapserver within a community
> > mapbuilder web browser client. I had question on part of the sample map
> > file that you sent:
> > OUTPUTFORMAT
> > NAME jpeg2000
> > DRIVER "GDAL/JP2ECW"
> > MIMETYPE "image/jpeg2000"
> > FORMATOPTION "TARGET=95"
> > IMAGEMODE RGB
> > END
> > What does TARGET=95 mean?
> John,
> This means that I am requesting 95% reduction in image size during
> compression - ie. 20:1 compression.
> > I am having good success (as far as image quality and small size
> > downloaded to the browser) with displaying my image data as jpeg within
> > community mapbuilder as an example
> > <FormatList>
> > <Format current="1">image/jpeg</Format>
> > </FormatList>
> > But when I try displaying it as a png as an example. I get poor quality
> > as far as the color.
> > <FormatList>
> > <Format current="1">image/png</Format>
> > </FormatList>
> You like want PNG24 format. The plain PNG format results in a reduction
> to 8bit which causes a lot of damage to the image. The predefined 24bit
> PNG output format is called "PNG24", and has a mimetype of
> "image/png; mode=24bit"
> > What application do you use to create your .ECW files?
> The original ecw file I was serving from was one I downloaded from
> geotorrent.org. But I do sometimes use gdal_translate to produce
> ecw files.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061130/9c71c7ad/attachment.html
