Mapserv not accepting POST method
Richard Greenwood
richard.greenwood at GMAIL.COM
Sat Nov 17 09:21:55 EST 2007
On Nov 17, 2007 4:43 AM, Jeff Copes <jeff at bluemoonweather.org> wrote:
> Thanks for replying guys. I had tried putting the GET command in the html
> page and tried your posted link and Firefox wanted to download the mapserv
> executable from my web server root and was able to do so. I tried William's
> reply, too, and got the same error as before about mapserv not taking a POST
> request. I tried Safari this AM, and the same results. I am able to serve
> html pages and php from any directory.
> Could the mapserv version I am using be what is causing this problem? Is
> there a command I can run on the command line or through my web service to
> get the version info and re-form a reply? I am running OS X 10.4.10, and the
> apache in my previous post. Thanks again, and please advise when you can.
Sounds like the your mapserv is not executable. Try:
chmod +x mapserv
then to check you modification:
ls -Fal
and it should look something like:
-rwxr-xr-x 1 rich admin 1220132 Sep 23 11:40 mapserv*
If that doesn't resolve it, then check that your cgi directory is
setup in your Apache configuration (/etc/httpd/httpd.conf) Should look
something like:
ScriptAlias /cgi-bin/ "/Library/www/cgi-bin/"
Basically this instructs Apache to execute files in the specified
directory, rather than serve them as static content. (Remember to
restart Apache after modifying the config).
HTH,
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
