Mapserv not accepting POST method
Jeff Copes
jeff at BLUEMOONWEATHER.ORG
Sat Nov 17 19:04:08 EST 2007
Richard,
Thanks for your reply. This is a weird one.
The permissions were the first thing I checked. I have my ls aliased to ls
-F.
-rwxrwxr-x 1 satellit wheel 1504560 Nov 14 04:57 mapserv*
I checked the ScriptAlias variable, it is pointed to the correct space.
I will keep looking.
Jeff
Richard Greenwood wrote:
> On Nov 17, 2007 4:43 AM, Jeff Copes <jeff at bluemoonweather.org> wrote:
>> Thanks for replying guys. I had tried putting the GET command in the html
>> page and tried your posted link and Firefox wanted to download the
>> mapserv
>> executable from my web server root and was able to do so. I tried
>> William's
>> reply, too, and got the same error as before about mapserv not taking a
>> POST
>> request. I tried Safari this AM, and the same results. I am able to serve
>> html pages and php from any directory.
>> Could the mapserv version I am using be what is causing this problem? Is
>> there a command I can run on the command line or through my web service
>> to
>> get the version info and re-form a reply? I am running OS X 10.4.10, and
>> the
>> apache in my previous post. Thanks again, and please advise when you can.
> Sounds like the your mapserv is not executable. Try:
> chmod +x mapserv
> then to check you modification:
> ls -Fal
> and it should look something like:
> -rwxr-xr-x 1 rich admin 1220132 Sep 23 11:40 mapserv*
> If that doesn't resolve it, then check that your cgi directory is
> setup in your Apache configuration (/etc/httpd/httpd.conf) Should look
> something like:
> ScriptAlias /cgi-bin/ "/Library/www/cgi-bin/"
> Basically this instructs Apache to execute files in the specified
> directory, rather than serve them as static content. (Remember to
> restart Apache after modifying the config).
> HTH,
> Richard Greenwood
> richard.greenwood at gmail.com
> www.greenwoodmap.com
View this message in context: http://www.nabble.com/Mapserv-not-accepting-POST-method-tf4818882.html#a13814915
Sent from the Mapserver - User mailing list archive at Nabble.com.
