Mapserv not accepting POST method
Jeff Copes
jeff at BLUEMOONWEATHER.ORG
Sun Nov 18 23:10:52 EST 2007
William and Richard,
I reinstalled MapServer and the associated framework from William
Kyngesburye's distribution. Works fine. I had to delete receipts, but after
that the install went well. The other packages from GRASS I will reinstall
from the disk later.
Thanks for your help. I will continue to monitor posts where I can be
helpful as I get more involved with the application.
Jeff
Jeff Copes wrote:
> Hi all.
> Working with the MapServer, apache 1.3.33 on Mac OS Tiger.
> Invoking mapserv from:
> <body>
> <form method=POST action="CGI-Executables/mapserv" >
> <input type="submit" value="Maps">
> <input type="hidden" name="map"
> value="/Library/WebServer/Maps/helloworld.map">
> <input type="hidden" name="map_web_imagepath"
> value="/Library/WebServer/Images">
> </form>
> </body>
> This error is displayed:
> The requested method POST is not allowed for the URL
> /CGI-Executables/mapserv
> The mapserv executable is in the CGI-Executables directory, has correct
> permissions, the other elements exist in the specified place, apache is
> working, the directories have the right permissions. Postdata is being
> flushed, browser cache is flushed. I hope this isn't something obvious, I
> don't need the beating.
> Thanks,
> Jeff
View this message in context: http://www.nabble.com/Mapserv-not-accepting-POST-method-tf4818882.html#a13827529
Sent from the Mapserver - User mailing list archive at Nabble.com.
