under laid layer does not diplay
Gagan Bansal
gagan.bansal at RELIANCEADA.COM
Thu Nov 22 04:38:49 EST 2007
Skipped content of type multipart/mixed-------------- next part --------------
MAP
# Start of map file
# Sample map file for a chameleon app.
NAME DEMO
STATUS ON
SIZE 1200 900
SYMBOLSET ../etc/symbols.sym
#EXTENT 270000 2100000 279000 2110000
EXTENT -197273 789426 2735369 4103591
UNITS METERS
SHAPEPATH "../data1"
IMAGECOLOR 255 255 255
FONTSET ../etc/fonts.txt
TRANSPARENT OFF
OUTPUTFORMAT
NAME png24
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
# Start of web interface definition
WEB
#MINSCALE 2000000
#MAXSCALE 50000000
MAXSCALE 16125993
# On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
# of the drive where the .MAP file resides.
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
# LOG "/tmp/gmap.log"
METADATA
END
END
# Start of reference map
REFERENCE
IMAGE images/keymap.gif
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
SIZE 120 90
END
PROJECTION
"init=epsg:32643"
END
# Start of layer definitions
#----------------Building-------#
LAYER
GROUP "Polygon"
NAME "build_utm"
CONNECTIONTYPE oraclespatial
CONNECTION "scott/bigmaps at orcl"
#DATA building
DATA "GEOM FROM BUILD_UTM USING UNIQUE OBJECTID SRID 32643 VERSION 10g"
#DATA "GEOM FROM (select t.geom,t.objectid,t.bldgname from build_utm t where SDO_WITHIN_DISTANCE(t.geom, SDO_GEOMETRY(2001,32643,SDO_POINT_TYPE( 273977.776, 2104464.25,NULL),NULL,NULL), 'distance =1000 querytype=FILTER') = 'TRUE') USING UNIQUE OBJECTID SRID 32643 VERSION 10g"
METADATA
"DESCRIPTION" "building"
"RESULT_FIELDS" "BLDGNAME"
"GROUP" "Polygon"
"LAYER" "build_utm"
"QUERYABLE" "TRUE"
"SEARCHFIELD" "OBJECTID"
END
TYPE POLYGON
STATUS OFF
CLASS
NAME "BUILDING"
COLOR 200 255 0
OUTLINECOLOR 120 120 120
TEMPLATE "C:/ttt_query1.html"
END
TOLERANCE 5
END # Layer
##########LAYER States ##############
LAYER
GROUP "Polygon"
NAME "states_utm"
DATA "GEOM FROM states_utm USING UNIQUE OBJECTID SRID 32643 VERSION 10g"
METADATA
"DESCRIPTION" "States"
"RESULT_FIELDS" "STATENAME"
"GROUP" "Polygon"
"LAYER" "states_utm"
"QUERYABLE" "TRUE"
END
TYPE POLYGON
STATUS ON
CLASS
NAME "States"
COLOR 255 255 190
OUTLINECOLOR 0 0 0
#OUTLINEWIDTH 0.40
END
TOLERANCE 5
END # Layer
##########LAYER ##############
##########LAYER City ##############
LAYER
GROUP "Polygon"
NAME "city_utm"
DATA "GEOMPG FROM city_UTM USING UNIQUE OBJECTID SRID 32643 VERSION 10g"
METADATA
"DESCRIPTION" "City"
"RESULT_FIELDS" "CITY"
"GROUP" "Polygon"
"LAYER" "city_utm"
"QUERYABLE" "TRUE"
END
TYPE POLYGON
STATUS ON
CLASS
NAME "City"
COLOR 255 255 240
OUTLINECOLOR 0 0 0
END
TOLERANCE 5
END # Layer
##########LAYER LandUse###############
LAYER
GROUP "Polygon"
NAME "LU_MUM_UTM"
DATA "GEOM FROM LU_MUM_UTM USING UNIQUE Type SRID 32643 VERSION 10g"
CLASSITEM "TYPE"
METADATA
"DESCRIPTION" "Landuse"
"GROUP" "Polygon"
"LAYER" "LU_MUM_UTM"
"QUERYABLE" "FALSE"
END
TYPE POLYGON
STATUS ON
CLASS
NAME "Water Pools"
EXPRESSION "Ponds / Swimming"
COLOR 151 219 242
OUTLINECOLOR 151 219 242
END
CLASS
NAME "Water Bodies"
EXPRESSION /Canal|Drains|Forest|Hydrology - Others|Lakes|River|Reservoir/
COLOR 151 219 242
END
CLASS
NAME "Parks"
EXPRESSION /Golf Course|Park/
COLOR 163 215 115
OUTLINECOLOR 163 255 115
END
CLASS
NAME "Open Space"
EXPRESSION "Open Space"
COLOR 255 234 201
OUTLINECOLOR 255 234 201
END
CLASS
NAME "Sandy Area - Beach"
EXPRESSION "Sandy Area / Beach"
COLOR 225 225 225
OUTLINECOLOR 225 225 225
END
CLASS
NAME "Plantations"
EXPRESSION "Plantations"
COLOR 115 178 115
OUTLINECOLOR 115 178 115
END
CLASS
NAME "Play Ground Sports Complex"
EXPRESSION /Play Ground|Sports Complex/
COLOR 239 228 190
OUTLINECOLOR 239 228 190
END
CLASS
NAME "Rocky Area"
EXPRESSION "Rocky Area"
COLOR 168 112 0
OUTLINECOLOR 168 112 0
END
CLASS
NAME "Swampy-Marshy"
EXPRESSION "Swampy/Marshy"
COLOR 238 241 160
OUTLINECOLOR 238 241 160
END
CLASS
NAME "Traffic Islands"
EXPRESSION "Traffic Islands"
COLOR 156 156 156
OUTLINECOLOR 156 156 156
END
TOLERANCE 5
END # Layer
##########LAYER Railway##############
LAYER
GROUP "Line"
NAME "railway_utm"
DATA "GEOM FROM railway_utm"
#"GEOM FROM railway_utm USING UNIQUE OBJECTID SRID 32643 VERSION 10g"
METADATA
"DESCRIPTION" "railways"
"RESULT_FIELDS" "OBJECTID"
"GROUP" "Line"
"LAYER" "Railway"
END
TYPE Line
STATUS ON
CLASS
SYMBOL "cartoline"
color 154 154 154
size 2
END
TOLERANCE 5
END # Layer
##########LAYER Road##############
LAYER
GROUP "Line"
NAME "road_utm"
DATA "GEOM FROM MUM_RD_UTM USING UNIQUE OBJECTID SRID 32643 VERSION 10g"
CLASSITEM "SPEEDCLASS"
LABELITEM "STREETNAME"
METADATA
"DESCRIPTION" "Road"
"GROUP" "Line"
"LAYER" "Road"
END
TYPE Line
STATUS ON
TRANSPARENCY alpha
CLASS
NAME "HIGHWAY"
#MAXSCALE 75000
#MINSCALE 0
EXPRESSION ([SPEEDCLASS] >= 50)
#style
#SYMBOL 8
#SIZE 8
#COLOR 0 0 0
#end
style
SYMBOL 8
SIZE 7
COLOR 254 144 16
ANTIALIAS true
end
END
CLASS
NAME "MAJOR-ROADS"
MAXSCALE 75000
MINSCALE 0
EXPRESSION ([SPEEDCLASS] < 50 AND [SPEEDCLASS] >= 20)
#style
#SYMBOL 8
#SIZE 6
#COLOR 0 0 0
#end
style
SYMBOL 8
SIZE 5
COLOR 230 221 53
ANTIALIAS true
end
END
CLASS
NAME "MINOR-ROADS"
MAXSCALE 15000
MINSCALE 0
EXPRESSION ([SPEEDCLASS] < 20)
#style
#SYMBOL 8
#SIZE 5
#COLOR 0 0 0
#end
style
SYMBOL 8
SIZE 2
COLOR 104 104 104
ANTIALIAS true
end
END
TOLERANCE 5
END # Layer
##########LAYER Landmarks#############
LAYER
GROUP "Point"
NAME "landmarks_utm1"
DATA "GEOM FROM landmarks_utm USING UNIQUE OBJECTID SRID 32643 VERSION 10g"
FILTER "DISPLAYCLA = 1"
# CLASSITEM "DISPLAYCLA"
CLASSITEM "SYMBOLID"
LABELITEM "LANDMARKNA"
MAXSCALE 35000
METADATA
"DESCRIPTION" "Landmarks"
"RESULT_FIELDS" "LANDMARKNA"
"GROUP" "Point"
"LAYER" "Landmarks"
"QUERYABLE" "TRUE"
END
TYPE Point
STATUS ON
CLASS
NAME "garden"
EXPRESSION "P303"
style
SYMBOL "park2"
Size 18
COLOR 0 166 57
end
style
SYMBOL "park"
Size 18
COLOR 157 79 33
end
END
CLASS
NAME "petroleum"
EXPRESSION /P103|P452/
SYMBOL "petrol"
Size 18
COLOR 0 0 0
#LABEL
# COLOR 255 0 0
# FONT fritqat-italic
# TYPE truetype
# SIZE 8
# POSITION AUTO
# PARTIALS FALSE
#OUTLINECOLOR 255 255 255
#END
END
CLASS
NAME "bus-depot"
EXPRESSION "P174"
style
SYMBOL "bus-depot2"
Size 18
COLOR 255 255 255
end
style
SYMBOL "bus-depot"
Size 18
COLOR 0 56 147
end
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 8
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "railway-station"
EXPRESSION "P175"
style
SYMBOL "bus-depot2"
Size 18
COLOR 255 255 255
end
style
SYMBOL "railway"
Size 18
COLOR 0 56 147
end
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 6
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "university"
EXPRESSION "P201"
SYMBOL "university"
Size 18
COLOR 168 0 255
END
CLASS
NAME "school"
EXPRESSION "P202"
SYMBOL "school"
Size 18
COLOR 168 0 255
END
CLASS
NAME "postofc"
EXPRESSION "P251"
SYMBOL "postofc"
Size 18
COLOR 0 0 0
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 8
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "fire-station"
EXPRESSION "P257"
SYMBOL "fire-station"
Size 18
COLOR 168 0 0
END
CLASS
NAME "police"
EXPRESSION /P259|P264/
SYMBOL "police"
Size 18
COLOR 168 0 0
END
CLASS
NAME "cremation"
EXPRESSION "P307"
SYMBOL "cremation"
Size 18
COLOR 168 0 0
END
CLASS
NAME "cemetry"
EXPRESSION "p308"
SYMBOL "cemetry"
Size 18
COLOR 168 0 0
END
CLASS
NAME "mills"
EXPRESSION "P407"
SYMBOL "mills"
Size 18
COLOR 0 0 0
END
CLASS
NAME "gymkhana"
EXPRESSION "P451"
SYMBOL "gymkhana"
Size 18
COLOR 168 0 255
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 8
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "temple"
EXPRESSION "P458"
SYMBOL "temple"
Size 18
COLOR 168 0 0
END
CLASS
NAME "church"
EXPRESSION "P459"
SYMBOL "church"
Size 18
COLOR 0 0 0
END
CLASS
NAME "mosque"
EXPRESSION "P460"
SYMBOL "mosque"
Size 18
COLOR 0 200 0
END
CLASS
NAME "convention"
EXPRESSION "P463"
SYMBOL "conventional-halls"
Size 18
COLOR 168 0 255
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 8
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "cinema"
EXPRESSION "P464"
SYMBOL "cinema"
Size 18
COLOR 0 0 0
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 8
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "guruduara"
EXPRESSION "P466"
SYMBOL "guruduara"
Size 18
COLOR 255 255 0
END
CLASS
NAME "hospital"
EXPRESSION "P501"
SYMBOL "hospital"
Size 18
COLOR 168 0 0
END
CLASS
NAME "hotel"
EXPRESSION "P504"
SYMBOL "hotel"
Size 18
COLOR 0 0 0
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 8
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "guest-house"
EXPRESSION "P505"
SYMBOL "hotel"
Size 18
COLOR 0 0 0
END
CLASS
NAME "medical-college"
EXPRESSION "P507"
SYMBOL "mcollege"
Size 18
COLOR 0 0 255
END
CLASS
NAME "stadium"
EXPRESSION "P601"
SYMBOL "stadium"
Size 18
COLOR 168 0 255
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 8
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "science-museum"
EXPRESSION "P654"
SYMBOL "museum"
Size 18
COLOR 168 0 255
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 8
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "bank"
EXPRESSION "P7"
SYMBOL "bank"
Size 18
COLOR 0 0 0
END
TOLERANCE 5
END # Layer
LAYER
GROUP "Point"
NAME "landmarks_utm2"
FILTER "DISPLAYCLA = 2"
MAXSCALE 15000
METADATA
"GROUP" "Point"
"LAYER" "Landmarks"
"QUERYABLE" "TRUE"
END
TYPE Point
STATUS ON
CLASS
NAME "garden"
EXPRESSION "P303"
style
SYMBOL "park2"
Size 18
COLOR 0 166 57
end
style
SYMBOL "park"
Size 18
COLOR 157 79 33
end
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 6
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "petroleum"
SYMBOL "petrol"
Size 18
COLOR 0 0 0
#LABEL
# COLOR 255 0 0
# TYPE truetype
# SIZE 8
# POSITION AUTO
# PARTIALS FALSE
#END
END
CLASS
NAME "bus-depot"
EXPRESSION "P174"
style
SYMBOL "bus-depot2"
Size 18
COLOR 255 255 255
end
style
SYMBOL "bus-depot"
Size 18
COLOR 0 56 147
end
END
CLASS
EXPRESSION "P175"
style
SYMBOL "bus-depot2"
Size 18
COLOR 255 255 255
end
style
SYMBOL "railway"
Size 18
COLOR 0 56 147
end
END
CLASS
NAME "university"
EXPRESSION "P201"
SYMBOL "university"
Size 18
COLOR 168 0 255
END
CLASS
NAME "school"
EXPRESSION "P202"
SYMBOL "school"
Size 18
COLOR 168 0 255
END
CLASS
NAME "postofc"
EXPRESSION "P251"
SYMBOL "postofc"
Size 18
COLOR 0 0 0
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 6
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "fire-station"
EXPRESSION "P257"
Size 18
COLOR 168 0 0
END
CLASS
NAME "police"
SYMBOL "police"
Size 18
COLOR 168 0 0
END
CLASS
NAME "cremation"
EXPRESSION "P307"
SYMBOL "cremation"
Size 18
COLOR 168 0 0
END
CLASS
NAME "cemetry"
EXPRESSION "p308"
SYMBOL "cemetry"
Size 18
COLOR 168 0 0
END
CLASS
NAME "mills"
EXPRESSION "P407"
SYMBOL "mills"
Size 18
COLOR 0 0 0
END
CLASS
NAME "gymkhana"
EXPRESSION "P451"
SYMBOL "gymkhana"
Size 18
COLOR 168 0 255
END
CLASS
NAME "temple"
EXPRESSION "P458"
SYMBOL "temple"
Size 18
COLOR 168 0 0
END
CLASS
NAME "church"
EXPRESSION "P459"
SYMBOL "church"
Size 18
COLOR 0 0 0
END
CLASS
NAME "mosque"
EXPRESSION "P460"
SYMBOL "mosque"
Size 18
COLOR 0 200 0
END
CLASS
NAME "convention"
EXPRESSION "P463"
Size 18
COLOR 168 0 255
END
CLASS
NAME "cinema"
EXPRESSION "P464"
SYMBOL "cinema"
Size 18
COLOR 0 0 0
END
CLASS
NAME "guruduara"
EXPRESSION "P466"
SYMBOL "guruduara"
Size 18
COLOR 255 255 0
END
CLASS
NAME "hospital"
EXPRESSION "P501"
SYMBOL "hospital"
Size 18
COLOR 168 0 0
END
CLASS
NAME "hotel"
EXPRESSION "P504"
SYMBOL "hotel"
Size 18
COLOR 0 0 0
END
CLASS
NAME "guest-house"
EXPRESSION "P505"
SYMBOL "hotel"
Size 18
COLOR 0 0 0
END
CLASS
EXPRESSION "P507"
SYMBOL "mcollege"
Size 18
COLOR 0 0 255
END
CLASS
NAME "stadium"
EXPRESSION "P601"
SYMBOL "stadium"
Size 18
COLOR 168 0 255
END
CLASS
EXPRESSION "P654"
SYMBOL "museum"
Size 18
COLOR 168 0 255
END
CLASS
NAME "bank"
EXPRESSION "P7"
SYMBOL "bank"
Size 18
COLOR 0 0 0
END
TOLERANCE 5
END # Layer
LAYER
GROUP "Point"
NAME "landmarks_utm3"
FILTER "DISPLAYCLA = 3"
MAXSCALE 5000
METADATA
"GROUP" "Point"
"LAYER" "Landmarks"
"QUERYABLE" "TRUE"
END
TYPE Point
STATUS ON
CLASS
NAME "garden"
EXPRESSION "P303"
style
SYMBOL "park2"
Size 18
COLOR 0 166 57
end
style
SYMBOL "park"
Size 18
COLOR 157 79 33
end
END
CLASS
NAME "petroleum"
SYMBOL "petrol"
Size 18
COLOR 0 0 0
#LABEL
# COLOR 255 0 0
# TYPE truetype
# SIZE 8
# POSITION AUTO
# PARTIALS FALSE
#END
END
CLASS
NAME "bus-depot"
EXPRESSION "P174"
style
SYMBOL "bus-depot2"
Size 18
COLOR 255 255 255
end
style
SYMBOL "bus-depot"
Size 18
COLOR 0 56 147
end
END
CLASS
EXPRESSION "P175"
style
SYMBOL "bus-depot2"
Size 18
COLOR 255 255 255
end
style
SYMBOL "railway"
Size 18
COLOR 0 56 147
end
END
CLASS
NAME "university"
EXPRESSION "P201"
SYMBOL "university"
Size 18
COLOR 168 0 255
LABEL
COLOR 0 0 0
FONT fritqat-italic
TYPE truetype
SIZE 6
POSITION AUTO
PARTIALS FALSE
END
END
CLASS
NAME "school"
EXPRESSION "P202"
SYMBOL "school"
Size 18
COLOR 168 0 255
END
CLASS
NAME "postofc"
EXPRESSION "P251"
SYMBOL "postofc"
Size 18
COLOR 0 0 0
END
CLASS
NAME "fire-station"
EXPRESSION "P257"
Size 18
COLOR 168 0 0
END
CLASS
NAME "police"
SYMBOL "police"
Size 18
COLOR 168 0 0
END
CLASS
NAME "cremation"
EXPRESSION "P307"
SYMBOL "cremation"
Size 18
COLOR 168 0 0
END
CLASS
NAME "cemetry"
EXPRESSION "p308"
SYMBOL "cemetry"
Size 18
COLOR 168 0 0
END
CLASS
NAME "mills"
EXPRESSION "P407"
SYMBOL "mills"
Size 18
COLOR 0 0 0
END
CLASS
NAME "gymkhana"
EXPRESSION "P451"
SYMBOL "gymkhana"
Size 18
COLOR 168 0 255
END
CLASS
NAME "temple"
EXPRESSION "P458"
SYMBOL "temple"
Size 18
COLOR 168 0 0
END
CLASS
NAME "church"
EXPRESSION "P459"
SYMBOL "church"
Size 18
COLOR 0 0 0
END
CLASS
NAME "mosque"
EXPRESSION "P460"
SYMBOL "mosque"
Size 18
COLOR 0 200 0
END
CLASS
NAME "convention"
EXPRESSION "P463"
Size 18
COLOR 168 0 255
END
CLASS
NAME "cinema"
EXPRESSION "P464"
SYMBOL "cinema"
Size 18
COLOR 0 0 0
END
CLASS
NAME "guruduara"
EXPRESSION "P466"
SYMBOL "guruduara"
Size 18
COLOR 255 255 0
END
CLASS
NAME "hospital"
EXPRESSION "P501"
SYMBOL "hospital"
Size 18
COLOR 168 0 0
END
CLASS
NAME "hotel"
EXPRESSION "P504"
SYMBOL "hotel"
Size 18
COLOR 0 0 0
END
CLASS
NAME "guest-house"
EXPRESSION "P505"
SYMBOL "hotel"
Size 18
COLOR 0 0 0
END
CLASS
EXPRESSION "P507"
SYMBOL "mcollege"
Size 18
COLOR 0 0 255
END
CLASS
NAME "stadium"
EXPRESSION "P601"
SYMBOL "stadium"
Size 18
COLOR 168 0 255
END
CLASS
EXPRESSION "P654"
SYMBOL "museum"
Size 18
COLOR 168 0 255
END
CLASS
NAME "bank"
EXPRESSION "P7"
SYMBOL "bank"
Size 18
COLOR 0 0 0
END
TOLERANCE 5
END # Layer
END # Map File
