PHP_OGR problem
Milan Lazecky
el.migno at POST.CZ
Sat Nov 24 11:54:39 EST 2007
Thank you Guillaume
but it doesn't help.
I have IIS 5.1 - and I haven't found any options to do it there.
I am very confused about this. Can somebody help? Just some suggestions, I would try anything!
Once more - I cannot make php_ogr work in a web browser. When I use command line (php -q ... - php_ogr examples) it works. But when I try to open a php in web browser, it says this:
PHP Warning: PHP Startup: Unable to load dynamic library 'C:\Program Files\PHP\ext\php_ogr.dll' - Access denied. in Unknown on line 0
Thank you for your ideas.
Milan
> ------------ Původní zpráva ------------
> Od: Guillaume Sueur <guillaume.sueur at NEOGEO-ONLINE.NET>
> Předmět: Re: [UMN_MAPSERVER-USERS] PHP_OGR problem
> Datum: 22.11.2007 10:00:09
> Hi Milan,
> Maybe you're running IIS6 and you must explicitely authorize php_ogr.dll
> to be used by the internet user. I don't remember precisely, but it
> should be somewhere under the IIS administration console.
> Hope that helps
> Milan Lazecky a écrit :
> > Hi everybody.
> > Does anybody of you have experience with php_ogr.dll in Windows?
> > I can't make it work :-(
> > When I try in command line php.exe -q ogr2ogr.php...... it works great!
> > But when I try to run it in a web browser (yes I have edited the example files
> to work in the browser), it gives an "Access denied" error for php_ogr.dll.
> > Maybe I have some dependency problem, but I used the Dependency Walker for
> this library and it seems to be ok (well, I had to find a msjava.dll file on the
> web). All the libraries included in ms4w installation file I have copied into
> the C:\PHP folder (and this folder is also in system PATH). I really am
> confused, I don't know what I do wrong.
> > PHP is in the newest version, php_ogr is from the ms4w newest version.
> > Thank you very much!
> > Milan
> Guillaume SUEUR
> Expert SIG et OpenSource
> NEOGEO
> 46 RUE MATABIAU
> 31000 TOULOUSE
> 06 65 58 88 82
> Site web : http://www.neogeo-online.net
