[mapserver-users] loadWeb(): Unknown identifier. Parsing error
near (/ms4w/tmp/ms_tmp/):(line 1)
Michael Schulz
mschulz at webgis.de
Tue Oct 20 08:26:08 EDT 2009
are you using a mapserver version 5+? I guess the problem is then,
that the cgi syntax to modify map parameters has changed from version
4. The culprit could be the form element "map_web_imagepath" in your
helloworld.html. Try it without this element.
Read on about changing map files parameters via URL here:
http://mapserver.org/cgi/controls.html#changing-map-file-parameters-via-a-form-or-a-url
BTW: I thought the map parameter in helloworld.html needs the full
path, i.e. on windows it should read
"c:/ms4w/Apache/htdocs/helloworld.map"
Cheers, Michael
2009/10/20 <geetha at ttkmaps.com>:
> Hi all,
> I went through the thread were similar post was there for windows.I tried
> all possible ways to get it right,but still getting the same error.Need help
> in this.Thanks in advance.
> My helloworld.map file is:
> #hello world example
> MAP
> NAME "hello_world"
> SIZE 600 600
> IMAGECOLOR 249 245 186
> IMAGETYPE png
> EXTENT -1.00 -1.00 1.00 1.00 #geographical extent
> WEB
> TEMPLATE "c:/ms4w/Apache/htdocs/helloworld.html"
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/tmp/"
> END
> LAYER
> STATUS default
> TYPE point
> FEATURE
> POINTS 0.0 0.0 END
> TEXT "hello world"
> END
> CLASS
> STYLE
> COLOR 255 0 0
> END
> LABEL
> TYPE bitmap
> END
> END#END CLASS
> END#END LAYER
> END #END MAPFILE
> My helloworld.html file is:
> <html>
> <head><title>Map Server hello world</title></head>
> <body>
> <form method=POST action="/cgi-bin/mapserv.exe">
> <input type="submit" value="click me">
> <input type="hidden" name="map"
> value="/ms4w/Apache/htdocs/helloworld.map">
> <input type="hidden" name="map_web_imagepath"
> value="/ms4w/tmp/ms_tmp/">
> </form>
> <IMG SRC="[img]" width=400 height=300 border=0>
> </body>
> </html>
> And i call it using
> http://localhost/helloworld.html
> I have stored both in /ms4w/Apache/htdocs/
> newuser.
> mapserver-users at lists.osgeo.org
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100 Freiburg i. Br.
Tel: +49 (0)761 705798-102
Tel: +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
