[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
Tamas Szekeres
szekerest at gmail.com
Wed Oct 21 16:00:16 EDT 2009
Paul,
I've set up your data but it works for me:
http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=mssql2008.map
tried with the following binaries:
http://vbkto.dyndns.org/sdk/release-1500-gdal-1-6-mapserver-5-4.zip
http://vbkto.dyndns.org/sdk/release-1500-gdal-mapserver.zip
My mapfile:
MAP
NAME "SQL2008"
STATUS ON
SIZE 500 500
IMAGETYPE PNG
IMAGECOLOR 254 254 254
EXTENT -79.7892 -44.2426 -24.9958 -9.11775
LAYER
NAME "tblGeo_AmericaSul"
TYPE POLYGON
CONNECTIONTYPE PLUGIN
PLUGIN "msplugin_mssql2008.dll"
CONNECTION
"server=.\MSSQLSERVER2008;database=Maps;Integrated Security=true"
DATA "the_geom from tblGeo_AmericaSul USING UNIQUE
CodigoAmericaSul USING SRID=0"
STATUS DEFAULT
CLASS
STYLE
COLOR 255 0 0
END
END
END
END
Best regards,
Tamas
2009/10/21 Paul james <pauljame at gmail.com>
> Tamas, the actual error generated is:
> HTTP Error 502.2 - Bad Gateway
> The specified CGI application misbehaved by not returning a complete set of
> HTTP headers. The headers it did return are "".
> Using Windos 7 (IIS 7)
> Testing on Windows 2003, I got just a Blank image (no error message)...
> You can use the same mssql2008 data I sended you last time...
> Paul
> On Tue, Oct 20, 2009 at 4:56 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> Paul,
>> I couldn't reproduce your problem by using my data and the recent mapserv
>> version.
>> http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=sql2008.map
>> Could you provide your data for testing?
>> Best regards,
>> Tamas
>> 2009/10/20 Paul james <pauljame at gmail.com>
>> Hello Tamas
>>> Did you test that?
>>> Paul
>>> On Mon, Oct 19, 2009 at 3:40 PM, Paul james <pauljame at gmail.com>wrote:
>>>> Testing :
>>>> http://localhost/cgi-bin-54/mapserv.exe?map=C:/Mapserver/Mapfile/map.map&mode=map
>>>> Using Postgis connection works fine with same setup...
>>>> Using that mapfile with MAPSCRIPT/C# works fine as well...
>>>> The problem is CGI + MSSQL2008 Plugin
>>>> Mapfile:
>>>> MAP
>>>> EXTENT -79.7892 -34.2426 -24.9958 6.11775
>>>> FONTSET "..\Fontes\Fontes.txt"
>>>> IMAGECOLOR 230 254 254
>>>> IMAGETYPE png
>>>> SIZE 400 200
>>>> STATUS ON
>>>> UNITS dd
>>>> NAME "Geral"
>>>> OUTPUTFORMAT
>>>> NAME "png"
>>>> MIMETYPE "image/png"
>>>> DRIVER "GD/PNG"
>>>> EXTENSION "png"
>>>> IMAGEMODE "PC256"
>>>> TRANSPARENT TRUE
>>>> END
>>>> PROJECTION
>>>> 'proj=longlat'
>>>> 'ellps=WGS84'
>>>> 'datum=WGS84'
>>>> 'no_defs'
>>>> END
>>>> WEB
>>>> IMAGEPATH 'C:\map\temp'
>>>> IMAGEURL '/tmp/'
>>>> QUERYFORMAT text/html
>>>> LEGENDFORMAT text/html
>>>> BROWSEFORMAT text/html
>>>> END
>>>> LEGEND
>>>> STATUS ON
>>>> KEYSIZE 18 12
>>>> KEYSPACING 10 5
>>>> IMAGECOLOR 255 255 255
>>>> LABEL
>>>> TYPE BITMAP
>>>> SIZE MEDIUM
>>>> COLOR 0 0 89
>>>> END
>>>> TEMPLATE "..\template.html"
>>>> END
>>>> QUERYMAP
>>>> COLOR 255 0 0
>>>> SIZE -1 -1
>>>> STATUS ON
>>>> STYLE hilite
>>>> END
>>>> REFERENCE
>>>> IMAGE "..\reference.png"
>>>> STATUS on
>>>> SIZE 221 150
>>>> MINBOXSIZE 5
>>>> MAXBOXSIZE 150
>>>> COLOR -1 -1 -1
>>>> OUTLINECOLOR 255 0 0
>>>> MARKERSIZE 8
>>>> END
>>>> LAYER
>>>> NAME test
>>>> GROUP "tests"
>>>> TYPE POLYGON
>>>> STATUS ON
>>>> CONNECTION "server=x;Integrated Security=false;database=x;uid=x;pwd=x"
>>>> DATA "the_geom from viwgeo_paisbrasil USING UNIQUE oid USING SRID=0"
>>>> CLASS
>>>> COLOR 255 200 255
>>>> END
>>>> END
>>>> END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091021/677b242b/attachment.html
