[OpenDroneMap-users] OpenDroneMap-users Digest, Vol 2, Issue 35
Alex Mandel tech_dev at wildintellect.com
Mon Mar 30 19:07:50 PDT 2015
This is the capitalization bug.
https://github.com/OpenDroneMap/OpenDroneMap/issues/33
I think there's a fix in another branch waiting on testing, but we could
also go through and update all the sample data sets.
Thanks,
Alex
On 03/30/2015 10:43 AM, Aquila Imaging wrote:
> I experienced the same error with the pacifica data set. log details below
> Bundle path was set to:
> /home/aquila/pacifica/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
> Images path was set to: /home/aquila/pacifica/
> Images list path was set to:
> /home/aquila/pacifica/reconstruction-with-image-size-2400/pmvs/list.rd.txt
> Input model path was set to:
> /home/aquila/pacifica/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
> Output folder path was set to:
> /home/aquila/pacifica/reconstruction-with-image-size-2400-results/odm_texturing/
> The texture resolution was set to: 4096
> The resized resolution used in bundler was set to: 2400
> The resolution to texture with was set to: 3600
> Log file path was set to:
> /home/aquila/pacifica/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
> Successfully loaded 199789 polygons from file.
> Successfully read the bundle file.
> Successfully read the image list file.
> Error in OdmTexturing:
> Failed to read image:
> '/home/aquila/pacifica//IMG_4663.jpg'
> On Sun, Mar 29, 2015 at 9:05 PM, <opendronemap-users-request at lists.osgeo.org
>> wrote:
>> Send OpenDroneMap-users mailing list submissions to
>>         opendronemap-users at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>         opendronemap-users-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of OpenDroneMap-users digest..."
>> Today's Topics:
>>    1. Re: OpenDroneMap-users Digest, Vol 2, Issue 34 (Aquila Imaging)
>> Message: 1
>> Date: Sun, 29 Mar 2015 21:05:41 -0700
>> From: Aquila Imaging <aquilaimaging at gmail.com>
>> To: opendronemap-users at lists.osgeo.org
>> Subject: Re: [OpenDroneMap-users] OpenDroneMap-users Digest, Vol 2,
>>         Issue 34
>> Message-ID:
>>         <CAG8qAWrSdSUQhnf8aKy==
>> QmGZsA8f5RfEyLbjtJOTQNc7EDK-g at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Hello All,
>> I ran into an error processing the Langley data set. details below. Can you
>> point me in the direction of a fix for this? I attempted to re-run the
>> script from the step that failed, but got the same error.
>> Thanks in advance.
>> error:
>> /home/aquila/langley/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
>> Images path was set to: /home/aquila/langley/
>> /home/aquila/langley/reconstruction-with-image-size-2400/pmvs/list.rd.txt
>> /home/aquila/langley/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
>> /home/aquila/langley/reconstruction-with-image-size-2400-results/odm_texturing/
>> /home/aquila/langley/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
>> Successfully loaded 199762 polygons from file.
>> '/home/aquila/langley//IMG_0525.jpg'
>> Regards,
>> Justin
>> On Sun, Mar 29, 2015 at 2:20 PM, <
>>> Today's Topics:
>>>    1. Fwd: OpenDroneMap-users Digest, Vol 2, Issue 33 (Chris House)
>>> Message: 1
>>> Date: Sun, 29 Mar 2015 17:20:50 -0400
>>> From: Chris House <housec01 at gmail.com>
>>> Subject: [OpenDroneMap-users] Fwd: OpenDroneMap-users Digest, Vol 2,
>>>         Issue 33
>>> Message-ID:
>>>         <CAKbExziaPOGk=
>>> Xk+OUnA-XnptnJ909ZYwhEZqU7vqg5WfNuFSw at mail.gmail.com>
>>> Per Dennis response I also was able to use
>>> ../OpenDroneMap/run.pl --odm_georeferencing-useGcp "false"
>>> and get the stitched image.  However there isn't any georeference
>>> information.  How do I use this in QGIS with my other data? Do I have to
>>> manual georeference or did I do something wrong...again?
>>> ---------- Forwarded message ----------
>>> From: <opendronemap-users-request at lists.osgeo.org>
>>> Date: Mar 29, 2015 5:01 PM
>>> Subject: OpenDroneMap-users Digest, Vol 2, Issue 33
>>> To: <opendronemap-users at lists.osgeo.org>
>>> Cc:
>>>> Today's Topics:
>>>>    1. Re: OpenDroneMap-users Digest, Vol 2, Issue 30 (Aquila Imaging)
>>>> Message: 1
>>>> Date: Sun, 29 Mar 2015 14:01:36 -0700
>>>>         Issue 30
>>>> Message-ID:
>>>>         <CAG8qAWoKEkmr3wLcOhrwydtCgajumKOh1i6k+Z7OxUEO=
>>>> KB84w at mail.gmail.com>
>>>> Hello all,
>>>> I used the following from Dennis w/ success:
>>>> That will start everything from the beginning. A better way may be to
>> do
>>>> this which should start you from the georeferencing step:
>>>> ../OpenDroneMap/run.pl --start-with "odm_georeferencing"
>>>> Thanks for the clarification!
>>>> Regards,
>>>> Justin
>>>> On Thu, Mar 26, 2015 at 11:52 AM, <
>>>>> Today's Topics:
>>>>>    1. step by step using sensefly swinglet (Chris)
>>>>>    2. Re: Orthophoto without georeferencing (Stephen Mather)
>>>>>    3. Re: step by step using sensefly swinglet (Dennis Baldwin)
>>>>>    4. Georef (Bruno Oliveira)
>>>>>    5. OpenDroneMap optimization questions (En Li)
>>>>>    6. Re: OpenDroneMap optimization questions (Dennis Baldwin)
>>>>> Message: 1
>>>>> Date: Wed, 25 Mar 2015 16:00:52 -0400
>>>>> From: Chris <housec01 at gmail.com>
>>>>> Subject: [OpenDroneMap-users] step by step using sensefly swinglet
>>>>> Message-ID: <551313F4.7090703 at gmail.com>
>>>>> Content-Type: text/plain; charset=utf-8; format=flowed
>>>>> Hi All,
>>>>> On Smathermather's Weblog there is an example shown of a mesh output
>>> and
>>>>> orthophoto using the sensefly swinglet cam to collect the imagery.
>>> Does
>>>>> anyone have the step by step to get the orthophoto? I was able to
>>> return
>>>>> a textured mesh but it eventually errored out with "error 256"  That
>> is
>>>>> related to the gcp file but i was under the impression if xy data was
>>> in
>>>>> the header file it would use that. Any help/direction would be
>>>>> appreciated!  My imagery was collected using swinglet cam as well.
>>>>> Thanks and awesome product!!
>>>>> Chris
>>>>> Message: 2
>>>>> Date: Wed, 25 Mar 2015 22:38:30 -0400
>>>>> From: Stephen Mather <stephen at smathermather.com>
>>>>> To: Rimvydas <naktinis at gmail.com>
>>>>> Cc: opendronemap-users <opendronemap-users at lists.osgeo.org>
>>>>> Subject: Re: [OpenDroneMap-users] Orthophoto without georeferencing
>>>>> Message-ID:
>>>>> CAPkJWLUL6yeB+1oYMD17efyPFbcV6acXCtvSnFgpKwBm_a7v8A at mail.gmail.com>
>>>>> Ah, yes I see what you mean. Photoscan, as far as I know, only does
>>> this
>>>>> because you have a 3D model that you can orient and basically declare
>>>> your
>>>>> Z axis, which is a clever approach. That means that Photoscan
>> actually
>>>>> gives you an orthophoto.
>>>>> Hugin is just stitching and blending, as I understand it. I know Alex
>>>>> Mandel and Michelle Tobias have a lot of experience with Hugin... .
>> No
>>>>> point in ODM recreating that functionality, I think (though willing
>> to
>>> be
>>>>> proven wrong) although plenty of reason to integrate that wonderful
>>>>> multiscalar blending algorithm... .
>>>>> Cheers,
>>>>> Best,
>>>>> Steve
>>>>> On Wed, Mar 25, 2015 at 10:30 AM, Rimvydas <naktinis at gmail.com>
>> wrote:
>>>>>> OK, I get what you mean. Maybe "orthophoto" is not the right word
>> in
>>> my
>>>>>> question. What I actually expect in my case is simply a mosaic
>> image
>>>>>> without any reference to real dimensions or location (something
>> like
>>>> what
>>>>>> Hugin or PhotoScan can produce).
>>>>>> On Wed, Mar 25, 2015 at 2:25 PM, Stephen Mather <
>>>>>>> wrote:
>>>>>>> Hi Rimvydas,
>>>>>>> What georeferencing info adds is knowledge of where the Z axis is.
>>>>>>> Without that knowledge, AFAIK, there's no real way to create an
>>> ortho
>>>>> from
>>>>>>> the mesh.
>>>>>>> Best,
>>>>>>> Steve
>>>>>>> On Mar 25, 2015 9:55 AM, "Rimvydas" <naktinis at gmail.com> wrote:
>>>>>>>> I've noticed that currently odm_orthophoto is only run after
>>>>>>>> odm_georeferencing, so if the image set does not have any
>>>>> georeferencing
>>>>>>>> information, it seems to be impossible to produce a stitched
>>>> orthophoto
>>>>>>>> with ODM alone.
>>>>>>>> As it is possible to produce a mesh without georeferencing
>>>> information
>>>>>>>> (via keypoint matching), it should in theory be possible to
>> produce
>>>> an
>>>>>>>> orthophoto mosaic as well. Does anyone know if this would be
>>> possible
>>>>> with
>>>>>>>> the current version of ODM (maybe with slight modifications)?
>>>>>>>> Maybe I should write to the dev mailing list instead?
>>>>>>>> Best regards,
>>>>>>>> Rimvydas
>>>>>>>> _______________________________________________
>>>>>>>> OpenDroneMap-users at lists.osgeo.org
>>>>>> Rimvydas
>>>>> -------------- next part --------------
>>>>> An HTML attachment was scrubbed...
>>>>> URL: <
>> http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150325/b259297e/attachment-0001.html
>>>>> Message: 3
>>>>> Date: Thu, 26 Mar 2015 09:17:48 -0500
>>>>> From: Dennis Baldwin <db at unmannedairlines.com>
>>>>> To: Chris <housec01 at gmail.com>
>>>>> Cc: opendronemap-users at lists.osgeo.org
>>>>> Subject: Re: [OpenDroneMap-users] step by step using sensefly
>> swinglet
>>>>> Message-ID:
>>>>>         <CAE_jkWt0NRnviq7NJgtQ4rRXVmRZHsPLJBWm=
>>>>> bcaNtRP9WdM2Q at mail.gmail.com>
>>>>> Chris,
>>>>> Check out the runtime parameters here:
>> https://github.com/OpenDroneMap/OpenDroneMap/wiki/Run-Time--Parameters
>>>>> If you scroll down you'll see a reference to
>>>>> which defaults to "true". You can see it here in the run script as
>>> well:
>> https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/run.pl#L107
>>>>> Looking at this line of code you'll see that when you set the value
>> to
>>>>> "false" this line gets executed:
>> https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/run.pl#L781
>>>>> That should extract the GPS info from your images and place them
>>>>> in odm_georeferencing/coordFile.txt. So my suggestion would be to run
>>>> your
>>>>> project again like this:
>>> do
>>>>> Good luck and let us know how you get along.
>>>>> Dennis
>>>>> On Wed, Mar 25, 2015 at 3:00 PM, Chris <housec01 at gmail.com> wrote:
>>>>>> Hi All,
>> output
>>>> and
>>>> Does
>>>> return
>>>>> a
>> is
>> was
>>>> in
>>>>>> Chris
>>>>> URL: <
>> http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150326/8af7212b/attachment-0001.html
>>>>> Message: 4
>>>>> Date: Thu, 26 Mar 2015 15:20:47 +0000
>>>>> From: Bruno Oliveira <bruno.manata.oliveira at gmail.com>
>>>>> To: opendronemap-users <opendronemap-users at lists.osgeo.org>,
>>>>>         opendronemap-dev at lists.osgeo.org
>>>>> Subject: [OpenDroneMap-users] Georef
>>>>> Message-ID:
>>>>> CAO-SbStQrcPTj4M+Vd-ctg8wqdK+ViPaNr8mu6fdsZwp1ymvWQ at mail.gmail.com>
>>>>> Hello,
>>>>> I have been digging on the Georef code and found this, after the
>>> Bundler
>>>>> file parsing, and creating a pose matrix (concatenating the
>> Bundler's R
>>>> and
>>>>> t matrices,
>>>>> *  pose = pose.inverse();    // Column negation    pose(0,2) =
>>>>> -1.0*pose(0,2);    pose(1,2) = -1.0*pose(1,2);    pose(2,2) =
>>>>> -1.0*pose(2,2);    pose(0,1) = -1.0*pose(0,1);    pose(1,1) =
>>>>> -1.0*pose(1,1);    pose(2,1) = -1.0*pose(2,1);    if (pose_ != NULL)
>>>>> {        delete pose_;        pose_ = NULL;    }    pose_ = new
>>>>> Eigen::Affine3f(pose);    rot =
>>> transform.matrix().topLeftCorner<3,3>();
>>>>>     // Calculate translation according to -R't and store in vector.
>>> t
>>>>> -rot.transpose()*t;        transform(0,3) = t(0);    transform(1,3) =
>>>>> t(1);    transform(2,3) = t(2);*
>>>>> Why would you estimate inverse pose, do the "column negation" and
>> after
>>>>> that do the *t = -rot.transpose()*t;  *(This is actually documented
>> in
>>>> the
>>>>> bundler file, what I dont' understand is why would you invert the
>>>> original
>>>>> pose matrix and do the "column negation")
>>>>> URL: <
>> http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150326/3a8b146b/attachment-0001.html
>>>>> Message: 5
>>>>> Date: Thu, 26 Mar 2015 12:00:31 -0400
>>>>> From: En Li <enli at umich.edu>
>>>>> Cc: Javier Jimenez Serrano <javierji at umich.edu>,        Danning Sun
>>>>>         <danning at umich.edu>
>>>>> Subject: [OpenDroneMap-users] OpenDroneMap optimization questions
>>>>> Message-ID:
>>>>>         <CAOsGJwk2Tmbt10fhvO+aSS5KhF=
>>>>> KjpBeFtGf38pB8tXEoTiXLQ at mail.gmail.com>
>>>>> Hey Guys:
>>>>> I hope you are all doing well! My name is David Li, I am computer
>>> science
>>>>> major from the University of Michigan. First I want to thank you all
>>> for
>>>>> your contribution to this project. Currently, my team and I are
>> trying
>>> to
>>>>> enable a drone to fly over the crops of mid to large farm owners to
>>>>> accomplish crop surveillance for them. We tried the opendronemap on
>> VM.
>>>> We
>>>>> tried to run ODM with around 70 photos and it took more than an hour
>> to
>>>>> finish. While we are impressed by the quality of the resulting
>> picture,
>>>> our
>>>>> sponsor has pointed out the image processing process was a little too
>>>> long.
>>>>> We were wondering if there are ways we could reduce this time so we
>> are
>>>>> closer to our sponsor's requirement. Any help would be wonderful!
>>> Thank
>>>>> you so much!
>>>>> En Li
>>>>> URL: <
>> http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150326/a7aaf590/attachment-0001.html
>>>>> Message: 6
>>>>> Date: Thu, 26 Mar 2015 13:52:58 -0500
>>>>> To: En Li <enli at umich.edu>
>>>>>         opendronemap-users at lists.osgeo.org, Danning Sun <
>>>>> Subject: Re: [OpenDroneMap-users] OpenDroneMap optimization questions
>>>>> Message-ID:
>>>>>         <CAE_jkWtJFJ-3H2u_2Qw4z3C-hUQFx=
>>>>> t7Uktnmd8iKOP19SW3bg at mail.gmail.com>
>>>>> What are your current VM specs and what is your sponsor's requirement
>>>>> regarding processing speed? I have a sample set of about 90 images
>>> that I
>>>>> use to test the latest ODM updates and it takes me a little over an
>>> hour
>>>> on
>>>>> an 8 GB Ubuntu 64 bit VM running on Amazon.
>>>>> On Thu, Mar 26, 2015 at 11:00 AM, En Li <enli at umich.edu> wrote:
>>>>>> Hey Guys:
>>>> science
>> all
>>>> for
>>> trying
>>>> to
>>> VM.
>>>>> We
>> hour
>>> to
>>> picture,
>>>>> our
>> too
>>>>> long.
>>> are
>>>> Thank
>>>>>> you so much!
>>>>>> En Li
>>>>> URL: <
>> http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150326/7a3452d1/attachment.html
>>>>> End of OpenDroneMap-users Digest, Vol 2, Issue 30
>>>> URL: <
>> http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150329/81a7a7e0/attachment.html
>>>> End of OpenDroneMap-users Digest, Vol 2, Issue 33
>>> URL: <
>> http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150329/f429bca4/attachment.html
>>> End of OpenDroneMap-users Digest, Vol 2, Issue 34
>> URL: <
>> http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150329/11c13e0b/attachment.html
>> End of OpenDroneMap-users Digest, Vol 2, Issue 35
More information about the OpenDroneMap-users mailing list
