[OpenLayers-Users] WFS-T example won't work because of error in gears_init.js line 51
Eric Lemoine eric.lemoine at camptocamp.com
Tue May 26 09:12:32 EDT 2009
On Tue, May 26, 2009 at 2:57 PM, Barbara Fiederer
<barbara.fiederer at web.de> wrote:
> Hi out there,
> I'm new to OpenLayers, so this might be an easy problem, but I can't get it solved on my own.
> At the moment I try to understand the examples on the OpenLayers.org-Site and to adjust them to my data. The easier ones worked out fine. But now I cannot get a WFS-T example to work. I tried two of them in the examples list of OpenLayers.org and for a last try the WFS-T Demo provided by Geoserver.
> Two examples throw the same error in gears_init.js line 51 "factory = new ActiveXObject('Gears.Factory'); ".
It may be that the error you're seeing in the FireBug console is
actually unrelated to Gears. Try removing the gears_init.js entry from
the jsfiles array in OpenLayers.js.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
